Originally Posted by sportyrick
If you don't have air brakes and not the usual engine driven air compressor but a few things run on air where is the air coming from? Sometimes they have a small electric motor driven compressor to run accessories. It sounds like a leak to me and you can't hear it?
The air door is high pressure/low volume, air suspension is medium pressure/high volume and an air horn (which is an available factory option) is high pressure/high volume. It wouldnt use an electric compressor because an electric HV/HP compressor would need an insane amount of current at 12 volts to run. It would still have the same compressor/governor system that an air brake bus would have, except it would only have one tank (no need for the primary/secondary redundant split system).
If it is a diesel it most likely would have the standard gear driven compressor on the driver's side. However he mentions the sound coming "from the Bendix", which to me says he has the front mount belt-drive Bendix compressor (possibly a gasser?), which has the governor mounted right on top, and no unloader hose... So the sound would come right from the assembly itself.
