Old 09-25-2022, 02:09 PM   #1
New please help
Bought a 1992 blue bird tc2000 bus. Looking for service manuals. Tried all websites with nothing. Also I need the air tanks fitting sizes for this model. Any help woild be greatly appreciated.
Fazlaga is offline   Reply With Quote
Old 09-25-2022, 02:47 PM   #2
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
I can't help with the manuals, but as to the air tank fittings...which ones do you mean? Your tanks will have multiple sized threaded fittings depending upon their purpose. Some will be 1/2-inch NPT (National Pipe Thread), some may be 3/8-inch, and some will certainly be 1/4-inch (such as drain fittings). You might also have some 3/4-inch and I've even seen 2" on some air starter tanks. The best thing to do is measure or remove the fitting you're trying to match.
Most of your air brake lines will probably be 3/8" poly, but some lengths might be 1/2". Lines to air bags (air springs, in the suspension, if you have those) can be 3/8" or 1/4". Keep in mind the line size is not the same as the pipe NPT size...you can have a 1/2" NPT fitting with a 3/8" poly line PTC (push to connect) fitting.
Old 09-25-2022, 03:40 PM   #3
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Fazlaga
I donít think any manual will have fitting sizes. You have to verify that your self. Either hire someone to work on your bus, or get under the bus and measure it yourself. A manual is, at best give you a bluebird part number, but I would not expect to find sizes listed.
William
Old 09-25-2022, 06:50 PM   #4
HazMatt's Avatar
Chassis: IH 3800, 8 window
That was a REALLY Good answer.
