Old 05-24-2020, 03:31 PM   #1
Engine: DT 466 Mechanical spicer 6+1. & 5.9 Cummins
Parking brake won’t release
I have a 2005 CE300 with hydro brakes and the parking brake will not release... has the Dt466 and Alison 2000 transmission. Any ideas?
alexzckary is offline   Reply With Quote
Old 06-03-2020, 12:02 PM   #2
Chassis: TC RE
Engine: 8.3 Cummins MD3060
Any emergency doors or hatches open? Have you been trying to eliminate wiring? The newer busses are equipped with interlock systems that set off alarms and/or will not start or release brakes if any doors or hatches are open. Likewise, if you try to circumvent these systems it can cause the same result.
JackE is offline   Reply With Quote
Old 07-03-2020, 12:59 AM   #3
PeteinSF's Avatar
Year: 2006
Coachwork: IC
Chassis: IC FE 9 Window
Rated Cap: 29850
If you have a wheelchair lift model, the outside door must be fully latched to disengage the parking brake. There is a micro switch in the lock receiver. No alarm will sound (like the roof exits do) just no brake release.
This system cuts off the pressurized air supply to the yellow plunger with two solenoid valves under the hood near to top of the firewall (or under the floor in my case).
Good luck.
PeteinSF is offline   Reply With Quote
Old 10-02-2021, 01:04 PM   #4
I have a similar issue! Help! �� I have disconnected the emergency doors and windows, I thought I had ground all the wires, Gracie started, but now the parking brake is locked on! Any ideas of how to bypass that?! ����
ACoupleAdventurers is offline   Reply With Quote
Old 10-04-2021, 03:30 PM   #5
PeteinSF's Avatar
Year: 2006
Coachwork: IC
Rated Cap: 29850
What model and year of bus?
Old 10-10-2021, 11:53 AM   #6
It’s a 2010 International DT466
I checked the post above and connected with Pizote, they suggested removing the parking brake solenoid, only, of course, I don’t have the same year bus so I’m not sure Where that part is.
Old 04-25-2022, 07:17 PM   #7
I just resolved a similar issue with my 2008 ce200 international. The solenoid to the two air valves was seeing 12v on the ground side. One quick wire to a ground on the bus and now it works like new!
Perpetually Average is offline   Reply With Quote
Old 09-07-2022, 12:56 PM   #8
I think I have a ground issue as well. Could you give a little more detail where to check for this wire?
FijiWiji is offline   Reply With Quote
Old 09-07-2022, 11:35 PM   #9
I’ll try to make it out to my bus in the next week to get a picture. There’s a post somewhere on this site that I haven’t been able to re-find with a semi detailed pdf drawing. On my bus in the engine bay on the drivers side connected to the cab are 2 silver pieces with airlines tee-ed to them. There’s a solenoid with 2 wires connected to them. That wire was checked with a multimeter and I saw hot on both sides. So I connected the ground side to a ground on the bus and the function returned. I’m not sure if this has any negative effects with other alarms but everything seems to be working.
Old 09-08-2022, 06:17 AM   #10
I also have similar issue
petrajimm is offline   Reply With Quote
