Passenger side parking brake
I freed up the other three, but the Passenger rear parking break is stuck hard. No amount of hitting the drum seems to loosen it. The push rod on the back of the brake chamber moves when deactivating the brake from inside the cab, so I am assuming that this isn't a grounded door safety switch?
I had run into that issue (ignition wouldn't start the bus, could only start from the switch in the back by the engine).
Can I use heat to break the pad free? Could a door safety switch be affecting this somehow even if the pushrod moves?
2006 Thomas safety liner, 31 foot rear engine, Cat C7, Alison 3000 for what it's worth.
