Old 08-06-2023, 06:53 PM   #1
Coachwork: SS-17 3700
Chassis: 3700 short bus
Engine: IHC 7.3 A170
Rated Cap: 21500
Re-surface or replace brake rotors
Hi, new to the forum.
If within specs can your re-surface brake rotors or is it better to replace them? I searched the forum but cannot find any info.
Thanks
Joe
jpitz31 is offline   Reply With Quote
Old 08-06-2023, 07:03 PM   #2
La Camioneta's Avatar
Year: 1994
Chassis: Ford B-700
Engine: 12V 5.9
Getting to be a lost art nowadays. If they meet thickness, take them to the crustiest old machine shop to make sure you get a good technician.
La Camioneta is offline   Reply With Quote
Old 08-07-2023, 07:15 AM   #3
Coachwork: IC
Chassis: CE200
Engine: VT-365
Rated Cap: 29760 GVWR
From what I have been reading, the "tone ring" inside the rotor is what the speed sensor uses to determine relative speed at each wheel. The sensor detects teeth inside the rotor. I guess these teeth get corrosion and become less detectable. I am unclear what all the ramifications are, but it sounded like, "if you replace just 1 rotor, the abs computer gets wonky and can leave you stuck." I don't know if this would be a problem if you replace just the front or rear 2 rotors, but let us know how it turns out. I know my rear rotors and brake components experience a lot more rust and corrosion than my front rotors. Maybe you can have the front rotors turned and only need to replace the rear.
Keep us posted!
Samarath is offline   Reply With Quote
Old 08-07-2023, 10:44 AM   #4
Chassis: International 1753
Engine: 6.9 International
IF they can be resurfaced, there are no problems in doing so. The problem is that very rarely are the rotors able to be turned, and that rarity has made the shops that do it nearly obsolete.
We've got a lathe with the big arbor capable of turning HD/MD rotors and drums. But like I said, >95% aren't capable due to rust, cracks, or wear. I use the lathe more often to fix brake shake caused by run out or parallelism issues. Most of the time, if the pads are worn, the rotors are too, thanks to the friction formulations that are being used nowadays. Pads nearly outlast the rotors any more.
Brake components always get replaced per axle. Rotors, pads, and even calipers and hoses always get replaced in pairs, as not doing so can and often does create a pull. and then you're redoing the job and replacing both anyways.
Old 08-07-2023, 11:17 AM   #5
Rated Cap: 21500
Thanks @Samarath for the great info.
Joe
Old 08-07-2023, 11:18 AM   #6
Rated Cap: 21500
Thanks @Booyah45828 for the good info.
Joe
Old 08-07-2023, 02:18 PM   #7
sportyrick's Avatar
Chassis: F33695
I am not sure about the larger rotors on medium duty vehicles but turning the rotors on cars is not worth the time or expense, I just replace them. Like Booyah says, it's a dying are because most of the time it doesn't work out. Get em turned because they are warped and put them on and drive it again and they warp again, once warped always warped, like some people I know.
Old 08-07-2023, 03:35 PM   #8
Rated Cap: 21500
Thanks @sportyrick, Years ago I use to turn the rotors on my cars. But have not done that in many years.
Old 08-15-2023, 08:10 AM   #9
Tin Roadtube Vagrant's Avatar
Chassis: Chevy Kodiak
Engine: 3126B CAT
Rated Cap: 27K
I've had mine lathed/trued with good success. No follow up issues in the years following. Metal price is through the roof, rotors also through the roof, better off.
Tin Roadtube Vagrant is offline   Reply With Quote
Old 08-15-2023, 10:26 AM   #10
Chassis: Ford E450
Engine: V10 Gas
I can't tell you how many times I've taken rotors to the car parts store only to be told they can't be turned. I think I was able to get one turned, once.
On the West Coast O'Reilly's turns rotors. Won't hurt to try, they're not going to turn one that is bad.
brakes, machine, re-surface, turn
