Old 05-23-2023, 04:59 PM   #1
Engine: 24 valve cummins, 5.9L
Trouble shooting the ultimate spongy brake pedal
Hey all,
just purchased a 2000 bluebird bus, TC front engine. After replacing a bad alternator my next job is to fix the hydraulic braking system. The symptoms are: Almost no pressure felt in the pedal until the final 10% of pedal travel and brake light and buzzer both sound constantly from moment brake pedal is first touched, until engine is shut down.
I tried topping up reservoir to see if the warning would stop, but no luck. Previous owner said he thought it was a leak, but my feeling is it could be a failed pump? my research has made me think theres a hydraulic engine driven pump, as well as an electric back up.
Whats the best way to isolate and diagnose which is the problem?
Thanks in advance for any help!
Bluebird_Rory is offline   Reply With Quote
Old 05-23-2023, 09:54 PM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Sounds like bendix hydro-max
That is the system with an electric motor used as a back up and that damn buzzer. There is out there, or was out there, on the World Wide Web, a operations/user/maintenance/troubleshooting manual a pdf file put out by bendix. I have a hydro max system on my 1989 international uhaul.
Hydro boost is the delco system.
William
Old 05-24-2023, 12:47 PM   #3
Engine: DT 466 Mech. Spicer 5 speed
Rated Cap: 34
http://1999southwind.com/DOWNLOAD/Bo...r%20Manual.pdf
Here is some good info.
PorchDog is offline   Reply With Quote
Old 05-26-2023, 11:19 AM   #4
Thanks so much, a lot more useful stuff inn there than anything else i could find.
Much appreciated!
