Old 08-30-2024, 01:12 PM   #1
Vacuum pressure questions
Hello fellow bus people! I have a question about the vacuum pressure. My bus seems to ride normally at 15inHg (idk what that really means but whatever not that important) but when I am accelerating for a long time it will slowly go down in pressure and eventually a warning light will pop up. All I need to do to raise the pressure is to take my foot off the gas for a second. I looked it up and people say it's normal and it's supposed to do that.
What is the difference in high and low pressure? I've been periodically taking my foot off the gas to keep the pressure up. I feel like maybe the engine doesn't work as hard when the pressure is higher but the power is lower? I don't really know that's just going off of the sounds the engine makes.
Does the vacuum pressure correlate with the gas mileage somehow?
I am not mechanically inclined, so please keep the answers somewhat simple, I tried looking this up online and could speaking in Mechanic
1976internat1603 is offline   Reply With Quote
Old 08-30-2024, 01:15 PM   #2
Here is a picture for reference, the first is normal, and the second is a couple minutes later after continuous acceleration
Old 08-30-2024, 02:46 PM   #3
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
i have never had anything with a low vacuum warning?
as far as the vacuum pressure readings that is normal my old truck hold about 17 at idle and if i really get in it it will go down to around 4-5.
what else is being controlled by vacuum that you need a warning for on low vacuum?
Old 08-30-2024, 03:11 PM   #4
s2mikon's Avatar
Engine: Cummins 8.3
The low vacuum warning is for the juice brakes. There is a check valve that is leaking. In Hg is inches of mercury as in the metal not the car or musician. It is the opposite of pressure as we know it. Going down hill it will go to around 23 In Hg or higher and up hill drop to 6 or lower. It is a good indicator of load and altitude. The higher in altitude you go the lower the idle vacuum will be. If you know the calibration of the power valve in your carburetor in inches of mercury you can drive it to stay above that set point.
s2mikon is offline   Reply With Quote
Old 08-30-2024, 06:22 PM   #5
Year: 86
Chassis: Ford B700
Engine: 8.2
you sir just taught me something i didnt know.
i have always built and used older vehicles but everything has always been below the mason dixon for lack of better words.
NC to TX stuff.
i thought of northern stuff as a carb adjustment and never a power valve adjustment? i do power valves for test and tune or sputter backflow/flash issues never thought of one for altitude issues.
but makes since for tuning for the altitude that you are in.
in the military i have been to more places overseas than i have states in the US and i have only lived in 2 texas and north carolina some time at pendleton but i call that just visiting
Old 08-30-2024, 06:40 PM   #6
Year: 86
Chassis: Ford B700
Engine: 8.2
just stuff in my head? that vacuum system has to be perfect.
i didnt see what the OP had but brake booster, vacuum advance, pcv, egr would have to be perfect.deleye
my old stuff?
everything is plugged or has block off plates.
age of the vehicle i would do an egr delete and depending on the carb a spacer
Old 08-30-2024, 07:01 PM   #7
Year: 86
Chassis: Ford B700
Engine: 8.2
one more?
where are you reading vacuum from?
carb? intake?
whatever port?
brake booster?
need to know engine vacuum before we trouble shoot brake booster or dizzy problems
sounds like nto me you have a brake booster issue.
if you do it yourself pay attention to pushrod length the of the master cylinder rod?
some are adjustable and some aint.
if you get one that has to be cut then grind a ball on the end and polish it the best you can. i have had one that was adjustable shaft but that was a nightmare to make work?
took it out and went back to the 1977 idea/parts?
Old 08-30-2024, 07:42 PM   #8
Coachwork: Busless for now
Mikon knows of what he speaks. From your other thread, I think you still have a leak at your brake booster. Make absolutely sure that new check valve fitting is not leaking.
When a gas engine idles with throttle closed, that is when vacuum is highest. The pistons are trying to pump air through the engine but the throttle plates won't let much air in. That causes negative pressure, or vacuum in the intake manifold. When you stomp on the "go" pedal, the throttle plates open and lots of air is welcomed into the intake manifold. More air means more pressure, which is less vacuum.
Your brake booster needs vacuum to work. If the check valve you put in is leaking, that means you are sucking air in from outside and the vacuum is too low.
I know how to diagnose pressure leaks with soapy water but not sure about vacuum leaks. I only know how to do it on outboard boat engine gearcases with a hand vacuum pump and pressure gauge.
Hopefully others can add more knowledge. Lots of smarter folks here than me. Good luck. I will be watching.
Kentucky Dreaming is offline   Reply With Quote
Old 08-30-2024, 07:50 PM   #9
Dang, I have a bunch of cute skunks hanging out here. Had 9, but I had to dispatch one that looked rabid last week
Old 08-31-2024, 12:36 AM   #10
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Two of a kind
Thank you for the detailed responses. I'll likely be asking some of these same questions soon, as I have a of the same 1976 equiptment.
After reading these associated threads, I expect to discover vacuum leaks, as well. With brakes, the only knowledge I have of boosters, is they go under short kids at restaurants.
I haven't traveled as many miles, with Noah yet, but I know my brakes are not right. He stops, very well. But the pedal needs a toe raise to release them. Not great.
Old 08-31-2024, 07:52 AM   #11
Year: 86
Chassis: Ford B700
Engine: 8.2
i use something like a Halloween smoke/fog machine to find vacuum leaks hook it to one line and pressurize the system and follow the smoke.
Old 08-31-2024, 08:37 AM   #12
s2mikon's Avatar
Engine: Cummins 8.3
It sounds like you may have a brake master cylinder issue. Is it a dual circuit or single.
Old 09-02-2024, 01:34 PM   #13
Hello everybody! Thank you all for your help! I was looking for a leak just by the sound it makes as the engine revs as that was how I found the original leak in my previous posts. I noticed that a very similar sound to the first leak I found is coming from the air filter part so soon I will look into that! A friend of mine who had multiple internationals also recommended that I look there so I'm 75% sure that's the culprit. I will update once I figure it out!
Old 09-02-2024, 01:35 PM   #14
Can you run the engine without the air filter or is that dangerous?
Old 09-02-2024, 01:44 PM   #15
s2mikon's Avatar
Engine: Cummins 8.3
Yes you can run it without the air cleaner. The air cleaner keeps dirt out of the engine and is good at suppressing backfires. Safety note: If starting an engine and it backfires while cranking keep the starter cranking and open the throttle. It will almost always suck the fire back into the manifold and consume it. You should have a fire extinguisher at your side when working on these old beasts. Don't ask me how I know. I don't know of a good reason to drive it down the road without the air cleaner though.
Old 09-02-2024, 02:35 PM   #16
I know first hand about having a fire extinguisher on hand. Almost burned down my 1970 Chevelle SS396 once, due to a loose hose clamp on the fuel line at the inlet to the Holley 750 double pumper.
BE CAREFUL!!!
Old 09-02-2024, 05:47 PM   #17
Ronnie's Avatar
Engine: 345 international V-8
One other note about vacuum, where is it reading it from? the intake manifold or the brake vacuum tank? If from the vacuum tank then the check valve as mentioned by others, or a leak in the tank, or booster.
If from the manifold then those are normal readings.
Old 09-02-2024, 09:21 PM   #18
BE CAREFUL!!!
Lost my first bus (prob my favorite of all i have ever had).. because 2 dummies poured gas in the carb of a chevelle in the shared garage trying to get it started .. they spilled a bunch and then cranked anyway (without the air cleaner).. it of course wasnt happy and belched fuel with flame.. they tried to beat the fire out with rags and their hoodies rather than grab one of the dozen fire extuingishers on the support poles of the building.. or one of the 3 out of my bus.. one of which was sitting on the floor by the front wheel.... by the time they figured out theres fire extuingishers everything was flaming and they did the right thing (for once) and ran out.. alas the chevelle was complete toast.. my bus was damaged badly enough the insurance said no to repairs.. to this day I wish I could find another little bus like that one..
Old 09-03-2024, 10:45 PM   #19
How do I know where it is coming from?
Old 09-04-2024, 07:13 AM   #20
Ronnie's Avatar
Follow the line from the gauge.
vacuum pressure
