Old 06-25-2023, 05:57 AM   #21
IDoMy0wnRacing's Avatar
Year: 1980
Coachwork: 1980 Gillig, 1990 Thomas
Chassis: Transit Coach
Engine: Cummins 855 w/RT-910 & CAT 3208 w/Allison MT643
Rated Cap: 78-Passenger
450-500 ft/lb with dry threads for both 3/4-16, and 1-1/8-16, .875" spherical radius nuts (Also known as "ball seat" nuts).
Ed
Cruising in your Skoolie is only half the fun...
You get to build it first.
IDoMy0wnRacing is offline   Reply With Quote
Old 06-25-2023, 06:06 AM   #22
Year: 1980
Originally Posted by Rwnielsen View Post
Sorry I confused the issue...I bought a torque multiplier to loosen and was looking at that torque device for tightening lug nuts. I should have been more clear
Torque Wrench, 3/4 drive with a rating of 100 ft-lbs to 650 ft-lbs.
Something along the lines of this: Torque Wrench 3/4-Inch Drive(100-650 ft-lbs/135-880Nm)
I picked up a Impact Socket Adapter Set to use the sockets that came with my Torque Multiplier with the 3/4 Torque Wrench that have..
Ed
Old 06-25-2023, 10:55 AM   #23
Tejon7's Avatar
Chassis: Crown Supercoach
Engine: Detroit 6-71TA, 10 sp.
Rated Cap: 90 (40')
I got a similar budget brand click-type torque wrench as well as adapters like you mentioned. Couldn't be happier. The electronic torque adapter looks pretty slick, but I figured that feeling/hearing a physical "click" is simpler for my monkey brain to process than listening for the "beep". Maybe I'll never need to do emergency tire work, but I feel good knowing that I could. And I've found several excuses already to remove wheels to make other work easier.
You'll need a drive extension if you want to torque your rear wheels. Something like this:
Sunex 4313 3/4-Inch Drive 13-Inch Extension https://a.co/d/fylLoUT.
You'll also need a helper or a variable-height stand that holds the extension level while you're torquing. I'm planning on welding a 24" tall "tree" with horizontal limbs every 2" that will hold the drive extension level (ish) with each lug nut. Will post pictures if I ever get around to making it.
Tejon7 is offline   Reply With Quote
Old 07-06-2023, 07:55 AM   #24
Tin Roadtube Vagrant's Avatar
Chassis: Chevy Kodiak
Engine: 3126B CAT
Rated Cap: 27K
You have a front axle rated too high for standard grease. Those hubs use Mobilith SHC 007 lithum complex semi-fluid synthetic grease. Fill the center cavity, rear cavity and a little in the hub cap. It is a flowing grease. We've had good returns with this grease. Never have to worry about inner seal leaks, it can't flow out well enough to cause a burn up.
Grab a clean cool whip tub and go to a local shop, you likely won't find this kind of grease in a small container. Most shops would give you the amount you need as a kind gesture.
Tin Roadtube Vagrant is offline   Reply With Quote
Old 07-06-2023, 11:28 AM   #25
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
That's the information I was looking for. Thank you. I didn't feel comfortable cleaning out the excess and sealing it up. A 5 gallon tub of it is over $500, I'll check around town like you said...with my cool whip tub
Rwnielsen is offline   Reply With Quote
Old 07-06-2023, 01:44 PM   #26
Engine: 3126B CAT
Rated Cap: 27K
Yup, crazy expensive. Our 15 gallon drum is 1/2 full after 10 years. Little goes a long way in a normal fleet.
Just another head up..... extra note, don't forget to pack (or sink) the bearings like normal grease.
When this system first came out in the 90's we had a rash of burn ups because mechanics were packing bearing only and leaving the hub belly's empty as you might with normal grease. It flowed/spun away into empty hub cavities and starved the bearings. You need to pack the bearings AND fill hub belly/cavities. Fill meaning a puddle from race to race, not pump-out-all-the-air full.
I was paranoid enough I'd put an inch or two of fluid grease in the hub cap and did one reeeeally fast manuever to slap the cap on before it could flow away. Only if I had a hub cap felt gasket... if just using silicone.... better not try this or you'll be leaking again if the grease flows and screws your silicone bead. It's about the consistency of cool, coagulated, gravy. Good Luck man!!!
Old 07-06-2023, 04:54 PM   #27
do you prefer this over oil bath? ive got oil bath on 2 of my busses and have had zero issues other than a couple wheel seal leaks I caught early as they are checked often.. (daily on a trip and at any stop I make I look for signs of leakage)..
my old 1978 Loadstar has standard grease hubs that have stayed full and clean.. I repacked them once a couple years ago as they looked a bit dirty then..
im guessing the standard grease hibs are a candidate for Semi-fluid but the oil bath need to stay oil bath?
Old 07-07-2023, 12:02 AM   #28
Rwnielsen's Avatar
Rated Cap: U/K
One final question...is the red colored SHC 007 the same as the dark blue (?) that was in my bearings? I mean, are they compatible?
Old 07-07-2023, 11:35 AM   #29
Engine: 3126B CAT
Rated Cap: 27K
You can convert to semi fluid anytime. We did. I'd have to go to literature, but it was 500K or 700K miles for cleaning and repacking these synthetic... or earlier if you feel "play" developing during a PM inspection.
Google SKF 1343. Make sure you don't put a standard bath style hub cap on with a fill port or some chucklehead with dump gear oil in it, guaranteed. These 1343 style caps have a small weatherproof breather to allow air to move out and in cleanly. SKF should have seal caps available for most hub configurations.
Sounds paranoid, but if you would have to reuse the transparent fillable oil hub cap, buff and paint the glass white. One, so that no one can see through it.. to reduce curiosity. Second, U.V. light kills. A plastic lens in direct sun let's the UV though. After a number of years parked in sun you can watch the green-lube Groeneveld version turn into a thicker, oxydized-looking, brown caramel where sun hits it. Not so with a closed cap. Don't understand why, but saw it happen.
Old 08-28-2023, 01:47 PM   #30
Rwnielsen's Avatar
Rated Cap: U/K
I've been reading up on this subject for a little bit now and have a much better understanding. Although I'm not sure what brand is in my wheels now (color) I find that SHC 007 is red, the Champion 00 I bought is amber and there are variations of each.
The NLGI (National Lubricating Grease Institute) ratings are key here. This is a cold consistency rating and what I currently have is #00 (semi-fluid, lithium based) with a 460 weight. NLGI ratings are from #00 to #4, #4 being very stiff. They are rated for extreme pressure and suitable for truck hubs.
I didn't know any of this when I cleaned out all the extra grease in my hubs and then was told the extra is absolutely necessary to avoid grease starvation due to centrifugal forces. I'm going to pack (fill) these like they were before and with a new gasket, torque the bolts to spec and hope for no leaks
Old 08-28-2023, 01:49 PM   #31
Rwnielsen's Avatar
Rated Cap: U/K
I know this isn't an exciting subject by I wanted to follow through with the info
