Old 09-25-2023, 12:16 PM   #1
Question Where/How to install air chuck on air brake tanks
Hey all,
I'm wanting to install an air chuck on my air tanks so I can fill up my tires when traveling without having to get to a truck stop first.
I have what appears to be two tanks. I believe the large one is my primary tank and the smaller one is my secondary tank. I also have a few inlets on them, and I'm not sure the best location to install the chuck.
Additionally, since I've never done this before, what parts/tools will I need to do this? Anything I should be careful about along the way?
Video here showing my tanks and different inlets.
Beeb2 is offline   Reply With Quote
Old 09-25-2023, 12:22 PM   #2
Engine: DT 466 Mech. Spicer 5 speed
Rated Cap: 34
Adding air accessories---
Watch this:
PorchDog is offline   Reply With Quote
Old 09-25-2023, 01:28 PM   #3
Thanks! That was really helpful!
I do not have air ride or an air seat or anything like that. As far as I know, I just have air brakes. So I can't trace back from an accessory in order to find the protected tank. Is the protection device he used at the end all I need?
Old 09-25-2023, 05:18 PM   #4
Rated Cap: 34
I think so. Once past that protection valve-- you can safely do what you want.
Old 09-25-2023, 05:52 PM   #5
yep porchdog has it right.. once past the protection valve you can set up any accessory you want.. if you never had anything but the brakes you can install a protection valve on the 3rd tank// or if its a combined single tankl with 3 chambers you can install a protection valve on an open port of the last tank
Old 09-25-2023, 11:56 PM   #6
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Hi Beeb, yes...as PD and CK said, once you are downstream of a pressure protection valve you can safely add accessories knowing that a leak in that portion of the system won't drop your braking system pressure below about 60 psi (commonly). The pressure protection valve I showed in that video is a pretty inexpensive and easy-to-find part. Thanks for thinking this through! Lots of folks don't consider the safety aspects...so, kudos to you.
And, PD, thanks for sharing the video!
Old 09-26-2023, 04:32 PM   #7
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
Look at the drain valves on your tanks - chances are one is actual a dual-tank. So one of the three could be your "wet tank" and the other two primary/secondary.
TSLABUS Build thread:
https://www.skoolie.net/forums/f11/j...ert-38328.html
TSLABUS YouTube Channel:
https://youtube.com/@thetslabus
Dbacks2k4 is offline   Reply With Quote
Old 09-26-2023, 06:30 PM   #8
nikitis's Avatar
Rated Cap: 29
This is a good idea. I may add a porthole from one of my tanks at the end to the outside of the bus on both sides, so I can hook up some pneumatic air tools straight to outside wall of the bus. Might even be good to do before I do the roof raise and just use the air hammer chisel for the rivet removal
Bus powered roof raise!
air brakes, air chuck, air tank, help me, question
