Old 12-22-2020, 04:33 AM   #1
Coachwork: Thomas School Bus
Chassis: Westcoaster ER
Air Compressor Size
I'm looking to get an Air Compressor to keep my bus tires inflated but need to know if a 6gal pancake 150psi will be sufficient. Sticker on bus says tires should be kept at 114psi but a truck stop put 105psi. Any suggestions on to size of compressor? Thanks
Cruzer is offline   Reply With Quote
Old 12-22-2020, 05:54 AM   #2
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
That compressor will work for you, with a 150 psi capacity. The tank size is almost irrelevant, if you're not in a rush (and are not running high-volume tools), especially if you're topping off and not trying to set beads or fill from flat.
