its theoreticaslly possible to do a delete on the ECM in a 07-09 Maxxforce.. the big issue is the EGR cooler on those.. the DPF and regen turned into an issue for short trips but the long haul oin a Maxxforce DT kept that decent.. they used a Variable vane turbo in 09 (unless its a 10 model engine).. then it had compound turbos.. the compound turbo setup was terrible on the maxxforce DT.. the VGT turbo could have some issues but usually just the actuator and thats not terrible to replace..
failed EGR coolers were commonplace.. (I and a buddy of mine just scrapped one this year that ran perfect when we got it.. ) the EGR cooler failed and the engine drank water.. Oops... bye bye engine....amazingly it made it to the scrap yard under its own power...
it was an 09 IC RE... we did harvest a lot of good computer and A/C parts from it
