Originally Posted by ralats
you are wrong 540 allison is a 5 speed transmission mt643 is a 6 foward speed transmission two different units two different units no internal parts are he same
the AT540 was an 'Auto truck' transmission in the 500 series with 4 forward gears (the second digit in the old allison numbers was the forward speeds).. an MT640 (643) was a Medium Truck transmission in the 600 series with 4 forward gears (2nd digit)..
an MT653 was a 5 speed (4 plus a granny gear) similar to the MT643..
an HT740 was a 4 speed in the Heavy truck 7 series.. (4 forward gears)..
there was an HT750 series also which was 5 forward gears (1st was a granny gear)
the 500 series had an SAE3 bell (big)
the 600 series had an SAE2 bell (bigger)
the 700 series had an SAE1 bell (Huge)
I bought my remanufactured MT643 from LKQ parts in marshfield missouri for $650.. I drove out and got it myself and installed it in my carpenter bus. . and ive driven 1000s of miles on it.. it has 4 (FOUR) forward gears.. theres a thread on my hopping in my didge pickup and going to get it..
they stil have some it appears....
https://lkqheavytruck.com/part-detai...ON&model=MT643
it replaced an AT545 which I blew up that had 4 (FOUR) forward gears. I drove 1000s of miles on that one..
allison manufacturers several 6 speed units as of today which are modern electronic units in the 1000,2000,3000 range.. the 3000 world series started in the mid 90s.. the 1000/2000 units used in everything from GMC diesel pickups to school busses came out in 2000...
I believe they stil make a 7 speed 4000 but im not sure..
a 9 speed was rumored for 2020 as a GMC transmission with allison's name on it..
thats pretty much the allison scoop as I know it..
