Old 07-10-2020, 11:29 AM   #61
Originally Posted by Gambler936 View Post
Does it come with a torque converter or do I need to get one as well
Hmmm I'm not sure. I *think* Chris aka CadillacKid got a TC with his. You'd probably want to call LKQ and ask.
Old 07-10-2020, 11:34 AM   #62
Engine: Dt466e
I called they still have a few 6 month warranty and it comes with a Tq
Gambler936 is offline   Reply With Quote
Old 07-10-2020, 11:44 AM   #63
SCORE!!!!
Old 07-10-2020, 12:05 PM   #64
Engine: Dt466e
SCORE!!!!
Yea I’m excited now just to see what the shop is gunna charge me what do you guys think is a fair charge for labor?
Old 07-10-2020, 01:39 PM   #65
TC is included.. ask them for the part number and verify it has a soeedometer TONE RING and not a Gear for the speedo. . or you can swap the Tone ring over from your AT545 to the 643
also you may need a different Flex-plate..
JohnBloem can help you with some of the parts list as his is a 466E like yours that was swapped.. my swap was into an older gen engine so the flex-plate part number wont be the same.
im sure you mentioned but i didnt see if you have air brakes or hydraulic.. if hydraulic you'll need a new parking brake assembly and bracket as those wont swapo over.. (mine is air brake so i didnt have that issue)..
Old 07-10-2020, 01:40 PM   #66
Engine: Dt466e
Thanks for the help Chris and it has air brakes. I’ll ask them when I call them on Monday or Tuesday.
Old 07-10-2020, 02:06 PM   #67
Engine: C7 Cat
Nice to hear you've got a solution to a crappy situation. Get er done and in no time at all you'll be building away and this chapter is long forgotten.
Cheers
Oscar1 is offline   Reply With Quote
Old 07-10-2020, 02:24 PM   #68
Engine: Dt466e
Cheers
Exactly it’ll be a good story once we’re done
Old 07-10-2020, 04:49 PM   #69
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
Originally Posted by WIbluebird View Post
Why did International ever think it was a good idea to sell DT466/AT545 buses? Why buy a bus that has been intentionally detuned just so it can barely coexist with that boat anchor of a transmission?
By not having a lockdown torque converter, the bus starts and stops smoother, as this is what it is doing quite a bit as it picks up and drops off kids. It is also designed to stay in a lower gear longer, again to make it smooth.
Old 07-10-2020, 10:23 PM   #70
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Rated Cap: 16
Did you do the swap your self? Or have a shop do it and if a shop did it how much did they charge you?
I had a shop do the swap, close to 2,000 for the labor (really had no choice, I was stuck on the road when it crapped out...) I was in a tourist trap area, too....
johnbloem1974 is offline   Reply With Quote
Old 07-10-2020, 10:27 PM   #71
Rated Cap: 16
As far as other bits needed, just had to have the flex plate, and make sure to remove the spacer. Also, the coolant line fittings were different. Was able to swap over the existing sensors like speed and reverse light switches.
Old 07-10-2020, 10:46 PM   #72
At least you can be spending money on an improvement.
(with the 643)
David
The Murder Bus
Old 07-11-2020, 06:11 AM   #73
That actually sounds a lot less terrible than I thought.
Old 07-11-2020, 08:40 AM   #74
the AT545 is an excellent route transmission and its simple inside as well.. I can rebuild one in a matter of hours on a bench esp since usually a failurei s a stuck valve or just worn out clutch packs.. the 545 has no bands, no lock up valves, a rather simple set up. the number of special tools to tear them apart and put them back together is minimal, clearancing the clutch packs is easy, a halfway competent fleet mechanic can learn to put them together and keep a spare or two.. they are relatively lightweight at 350 lbs so doing a remove and Replace is a matter of a couple hours for 2 mechanics in an equipped fleet garage.
as mentioned lockup can be a bit of a pain in route service.. however the MT643 was designed to only lockup in 'D' at about halfway through 3rd gear.. a bus geared for normal city with the ability to do some highway travel.. (11R22.5 tires and a 4.78 gear was a very common combo).. means that in neighborhoods doing stop to stop you would never reach lockup engagement speed on a 643.. the 643 will lockup in 2nd on Decel when you use the manual selector level and run it in '3' or '2' which makes it extremely nice for panic stops or steep hill descent.
in the modern busses lockup is controlled by the co,bo of the engine computer and the TCM.. school busses equipped with allison 2000 series transmissions are often programmed so when the Warning light 'Master' is set to on that lockup will be inhibited until you reach a higher speed and gear.. so that while running your route lockup stays off and when you turn the Master off then the trans will operate with lockup either beginning in high 2nd or in 3rd gear of the range. .
on either the MT643 or the AT545 making sure your shift modulator works is paramount to transmission longevity.. on mechanical engines its a cable that pulls in and out as you use the throttle.. this sets the throttle Valve pressure which not only determines when the unit shifts to the next gear but also how much pressure is applied to the clutch. a transmission shifting under full engine power needs more pressure.. or the shifts are early and slow which heats up and burns up the clutches..
on the 'E' engines that have fly-by wire.. (T444E,DT466E,cat 3126, C7) and others they use an electric modulator that the computer turns on and off based on how much load the engine is enduring..
rarely so the cable moidulators fail.. OFTEN the electric modulators fail and with it will soon go the transmission.. and if the modulator isnt tested and working your new transmission will not be long for the world either..
the 545 and 643 use the same modulator
testing them is rather easy.. if you drive at light throttle and shift from 3 to 4.. the nare able to punch it to the floor and have it downshift from 4 back to 3 your modulator works... again you drive at light throttle. . another way is if you get up high into third gear at mid throttle and then left off the peddle all the way and it goes up into 4 then your modulator works..
if it shifts the same time all the time regardless of light throttle or floored then your modulator is inoperative and needs fixed..
Old 07-20-2020, 08:11 PM   #75
Hope it all worked out
I didn't see a date as to when all this happened to you.....but I just want to say I hope you got your bus back home to N.Y. and were able to get her all fixed up and are now well on your way to building it out or trekking across the U.S.
littlewing is offline   Reply With Quote
Old 07-20-2020, 08:19 PM   #76
Engine: Dt466e
Nope not yet should be a few more weeks but we’re in no rush we’re going out to Colorado for a month
Old 08-12-2020, 09:30 PM   #77
Engine: Dt466e
Talking Ordered the transmission!!
Hey everybody quick update, I ordered a 643 transmission from lkq for 845 (with shipping and its remaned with a 6 month warranty). I need to order a flex plate but I cant seem to find one for the 643. Any help would be appreciated and any other parts i may need to buy also!! thanks again peeps!
Old 08-12-2020, 10:48 PM   #78
Coachwork: Gillig
Chassis: Phantom
Engine: ISM 10.8L, B400R
talk about the granny swap
Uhhhhhh....
JamesKS is offline   Reply With Quote
broke, first bus, tranmission
