Our rig -- 1996 with an Allison 3060.
After swapping starting batteries, we encountered a no-shift from neutral.
Tracing, we discovered a dedicated ground from the battery negative post to the control box on the rear bulkhead in the cab.
Similar to most wires/cables from the battery, this wire has a fuse (in this case, a circuit-breaker) near the potential for sparks.
The circuit-breaker *looked* fine... but a replacement got us going.
Or maybe it was a hot lead, start batteries to ECM.
That was a decade ago, and unless I write it in my op manual...
