The T444 is a good reliable engine so I wouldn’t worry too much about that. Is this a dog nose bus? I’m assuming it is, personally I’d go for hydraulic brakes over air but mine has air. Just make sure your state doesn’t require something special for air brakes as I think most do.
-Make sure it’s not rusty
-drive it around and make sure the transmission shifts smoothly
-look for fluid leaks
-get service history if available
-check the age of the tires and the tread, and for cracking on the sidewall
Keep in mind if there’s problems or repairs needed a seller is almost never going to be upfront or honest about it. Some will though.
