Welcome to the forum and congrats on the bus purchase.
Given that I regularly wack my head on the ceiling of my bus I SHOULD do a roof raise. I've thought a lot about it and I concluded that, were I to do a roof raise, I'd only raise it enough to KEEP from wacking my head. Why? It's what I THINK I'd like to do with my bus. I want to get off the beaten path and away from the main population corridors. That often means smaller roads and, potentially, lower overpasses. If you want to spend your time traveling the interstates and staying at RV parks close to the interstates then the sky's the limit, or at least whatever the limit is on the interstate overpasses.
What is the height of your roof now? Whatever it is add 18" to it and see where that puts you relative to the overpasses you think you might run into (figuratively speaking of course). I guess you also need to figure out what you might put ON the roof, a deck, solar panels, a 1 room schoolhouse?
