Welcome,
Many of us bend the rules a bit to get the bus home. The consensus is that yellow school buses being driven reasonably are somewhat invisible.
I have carried proof of insurance, temporary tag and purchase documents with me on the three that I have brought home. Drive the speed limit, make sure all of your lights work properly and use them as intended.
When you get it home, look into the regulations in your state for converting it to an RV. Most states exempt RV's from CDL requirements unless you are using the RV for business.
I have done as little to the bus as possible and get it titled and registered as an RV immediately. Rules do vary significantly from state to state. Definitely check your states rules yourself.
Good luck with your quest.
