06-17-2021, 06:53 PM
#141
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Engine: Cummins ISL 280
Rated Cap: 26,000 lbs
An antenna from Amazon
06-17-2021, 06:54 PM
#142
Year: 2009
Coachwork: Gillig
Chassis: G27E102
And another stubby one. Both are crap.
06-17-2021, 06:55 PM
#143
Year: 2009
Coachwork: Gillig
Chassis: G27E102
If anyone is interested in the designs, let me know.
The DIY ones are made to cover the T-Mobile, AT&T and Verizon bands as well as I could.
06-17-2021, 06:58 PM
#144
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Finnie shows a major dip around 2150MHz.
I also did measurements from 600 to 900MHz, to cover the frequencies used in rural areas. Particularly T-Mobile uses low frequencies, the lowest of all, starting at 617MHz - the famous Band 71.
The preliminary conclusion is that my own DIY designs seem to perform quite a lot better than the sub-$100 antennas from Amazon.
I'm trained in radio engineering so this is perhaps rather obscure stuff for many, but since internet-on-the-go is an essential part of the skoolie thing, I thought it to be appropriate to share it here, and perhaps I can help out some people with what I have learned.
06-18-2021, 06:51 AM
#145
Year: 2009
Coachwork: Gillig
Chassis: G27E102
The $399 inverter showed up so I did some quick tests.
06-18-2021, 06:52 AM
#146
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Idle current at 22.5V
#147
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Idle current at 26.5V
06-18-2021, 06:53 AM
#148
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Idle current at 28.5V
06-18-2021, 06:54 AM
#149
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Unloaded waveform
06-18-2021, 07:00 AM
#150
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Does not automatically recover from an under voltage condition. That’s annoying.
06-18-2021, 08:23 AM
#151
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Load on the power supply at 22.5V with a 100W lightbulb that draws pretty much exactly 100W on the AC side.
06-18-2021, 08:24 AM
#152
Year: 2009
Coachwork: Gillig
Chassis: G27E102
With median input voltage
#153
Year: 2009
Coachwork: Gillig
Chassis: G27E102
At the maximum input voltage
06-18-2021, 08:30 AM
#154
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Finally, a higher current load test. My big LiFePO4 batteries are in the bus, far away from here, so I rigged up a few NMC cells for a higher current test. These 8Ah cells can do 25C continuously, so running the heater at 1.5kW doesn’t impress them much.
The interconnections won’t win prizes, but I just wanted to see the waveform.
06-18-2021, 08:32 AM
#155
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Gillig 30ft Low Floor - the journey starts
At 1.5kW, the THD went down, interestingly enough.
Alright, that’s all I had time for, it’ll go into the bus next weekend.
Conclusion:
- Idle current (at room temperature) runs between 17 and 23W
- does not recover automatically from a low-voltage shutdown. A bone piercing shriek makes sure everyone within half a mile will know about it.
- the loaded efficiency at 100W seems good, if you accept the ~20W quiescent draw
- the waveform is pretty ugly at idle and low draws, but improves at kilowatt-level loads.
06-18-2021, 08:53 AM
#156
Year: 98
Thanks for doing the measurements ... I settled a couple of years ago on that brand.. mainly because it is a modular design and relative easy to get to the components to repair...the power components are on the outside of the heatsink.....I blew one up after messing with the current regulation in an attempt to eek another 300 watt out of it... Company sent me free MOSFETs or igbt's..I forgot...and a free oscillator control board.
Johan
06-20-2021, 06:41 PM
#157
Year: 2009
Coachwork: Gillig
Chassis: G27E102
I had to open the inverter already because the display had popped out. Hot glue isn’t quite the high grade mounting system I would have gone for…
06-20-2021, 06:43 PM
#158
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Apart from that, it looks like you would expect. But there’s no way that this thing can put out 5kW for any length of time. 800w each trough those tiny E-cores?
It works fine though. Starts my miter saw without complaints.
06-20-2021, 06:45 PM
#159
Year: 2009
Coachwork: Gillig
Chassis: G27E102
I did some fresh water tank puzzling, and cut some XPS panels too.
06-20-2021, 06:47 PM
#160
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Since I’m doing my conversion off grid, I needed to lay out the panels.
