When the symptom is "engine wont turn over" the problem IS NOT fuel filter, fuel, or lines. Nor is it past status of lubricant, coolant, or other fluids. It is going to be dead batteries, an electrical fault in the circuitry between batteries and starter (including computer modules), or a properly working circuit that disables the starter when a certain condition is present (such as an open escape hatch indication). Bus manufacturers use different methods to create safety circuits so you need to figure out how your manufacturer does them.
You've replaced the starter and recharged the batteries but have you done any diagnostic testing?
First test, load test on the fully charged batteries to ensure they have sufficient power to start a bus. Simple voltage tests can find a bad battery in some conditions (bad cell) but voltage alone can't tell you how healthy the battery is.
For the starter, the first check should have been (and still should be) testing for a starter solenoid "start" signal when the ignition is key or button is actuated to the "start" position. Odds are, having replaced the starter, that the signal is not present or is insufficient to actuate the solenoid. However, brand new parts (and rebuilds) can be bad right out of the box so the test shouldn't be bypassed.
Whatever you do, don't just throw parts at it. That gets expensive very fast and then you have a whole bunch of potential faults from all the disturbances created when replacing those parts.
