Thank you Rucker.
I spent a lot of time debating what to do about that lift. This isn't the kind that blocks the rear door, but is instead tucked up under the rear end, which I consider to be prime real estate for storage purposes.
This truck came out of northern Kentucky, so has some significant rust concerns. I was careful to make sure nothing critical was impacted (been there, done that), and I am confident the truck will be adequate to my need in the short to medium term.
Someone cut out all the wiring for the lift gate. The plates are badly rusted, as is much of the mechanism. I believe I can get it off the truck with two well placed cuts, after loosening the clamp that holds it up at the moment.
Long story short, I feel that removing the lift gate for any scrap value it might have, and replacing it with some welded framework storage, and a trailer hitch, will be of far more benefit to me.
This is not intended to be my final conversion, but more of a "good enough" conversion for my needs. I need a basic shelter that I can depend on for 3-8 years while I deal with some other of life's goals. Assuming those goal go well, I would be getting a much larger platform to work with and take my time picking it from a place with no rust!
I'll be starting the build thread here soon. I appreciate being welcomed back!
Jim
