Old 04-13-2024, 02:20 PM   #1
Help with rear heater
Hello all, New to this forum and skoolie life. I've been full time in my van for 2 years, but upon deciding I needed more room I purchased a 2003 Chevy Express 3500 Bluebird Microbird. Seats are out and built the bed platform. I am now in it full time, but still dealing with a couple issues. Can anyone tell me who I would go to for removal of the rear heater? I don't plan on using it and want it out. Also, until I can do that I would love to know why it gets hot to the touch when the bus is running. As far as I know the heater is not turned on, but there may be a switch I'm unaware of. Thank you advance to any that respond. Chasen
Chasen is offline   Reply With Quote
Old 04-14-2024, 11:00 AM   #2
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
So the rear heater should just be a small heat-exchanger (radiator) that is fed antifreeze from the engine.
To remove it, you would need to disconnect the hoses from the tee inside the engine bay (usually passenger side) and drain the lines of the antifreeze. Once the lines are drained, you should be able to backtrack the hoses and remove them as well as the rear radiator and it's protective cover.
Albatross is offline   Reply With Quote
Old 04-14-2024, 02:33 PM   #3
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
if you follow the heater hoses there should be a mechanical shut off valve you need to shut offyou can remove it yourself just have plenty of rags and a wet dry shop vac as it gets messy. drain your radiator first . also check the routing as you may have to loop the ends together to let your other heater get flow
mmoore6856 is offline   Reply With Quote
Old 04-14-2024, 02:34 PM   #4
mmoore6856's Avatar
Chassis: chevy
try to find someone that has your identical bus and did it as there will be lots of opionions here by some that dont even have a bus. just remember what mulder said
Old 04-14-2024, 09:54 PM   #5
Unpluggedone's Avatar
Year: 1967
Chassis: Dodge S500
Engine: Dodge 318
The heater on most bus’s is always circulating hot water from the engine. The fans blow air across to remove heat. There are usually at least 2 more, one for driver beat and defrost and one on passenger front for heat and defrost. All 3 in your case will be in one big loop, so you need to locate the hose, likely 1” in and out to the rear and connect them together to keep the other heaters working. Let us know where you are located, lots of handy folks more than willing to give you a hand
Unpluggedone is offline   Reply With Quote
Old 04-14-2024, 10:58 PM   #6
Thankyou. I am not mechanically inclined at all, but wish I were as it would not only be more convenient, but price effective.
I will have to seek out a professional.
Old 04-14-2024, 11:02 PM   #7
Thanks, There are two valves inline on two different houses underneath the bus. Are these the valves that you are referring to? I feel I need someone that knows what they are doing as opposed to me trying to accomplish this task. I don't want to f it up and create a safety issue out a mechanics bill.
Old 04-14-2024, 11:10 PM   #8
I'm new to how these forums work and so I apologize for my inability to make if clear who I was responding to in my previous posts. At any rate, thank you all for your replies. I am currently in Palm Springs getting some work done on the bus and attempting to sell the van I've been in for a couple years. It's not easy juggling 2 vehicles on the public streets. The brakes need replacing on the van and it's made things a bit more difficult while trying to sell without putting anymore money into it.
Old 04-15-2024, 09:01 AM   #9
Chassis: Chevy P30
Almost certainly, even without seeing them. This is because pretty much everything else on the bus is the sort of thing that you're going to want to be working full-time instead of putting a valve on it.
But, if you are selling the bus... Why bother with disconnecting the rear heater?
I would think it would actually be more worthwhile to leave it as-is, and then let whomever buys it decide if they want that heater or not... Since some people actually do like it.
Old 04-19-2024, 02:21 PM   #10
nikitis's Avatar
Rated Cap: 29
@Chasen
You can sort of follow what I did in my pictures on this post:
https://www.skoolie.net/forums/f11/s...tml#post506647
Also you don't have to drain the radiator if you clamp it like I did, it'll hold pressure if you clamp it tight enough.
Old 04-19-2024, 05:13 PM   #11
Chassis: Chevy P30
Originally Posted by nikitis View Post
@Chasen
My suggestion was actually to close the valves, and then remove the lines to/from the rear radiator.
Old 04-24-2024, 11:12 AM   #12
nikitis's Avatar
Rated Cap: 29
The reason I didn't want to do it close to the valves is that it would lose too much in pressure. My fluid was vacuumed sealed in to prevent cavitation. The distance from the valves to the otherside of the heater was too great and would have lost too much in the length.
If you close it off at the valves, then cut it after the heater, when you release it, the fluid will have to fill into the hose section with air and it will not be vacuumed sealed anymore.
Old 04-24-2024, 11:29 AM   #13
Chassis: Chevy P30
Oh, I was talking about closing the valves and removing all of the lines. Sure, you'd lose a gallon or three of coolant, but you'd have a nice ability to plug everything up without opening the system up at all.
Even if there's no valve on the return line, the brief second it would take to plug it back up with a screw or whatever the case might be with that particular system shouldn't actually leave it exposed to air since you'd have all of the coolant flowing back down and out of the hose.
The pull the hoses with the heater, since it doesn't really make sense to have all of that hose length with no load and little heat-transfer, unless you're really serious about having that massive of a reservoir of anti-freeze. Especially considering that those hoses would make it more difficult to flush or re-fill when the next time for service comes along.
Old 04-25-2024, 01:02 PM   #14
mmoore6856's Avatar
Chassis: chevy
What happens to the vacume when the water gets up to 200 degrees? If it was under any vacume the hoses would collapse
« Hello | Hello »
