my first thought...
There are often times, in the buses I have seen with my own eyes, more than two valves... My first thought is that you have missed a valve. I have seen them under the bus by the transmission heat exchanger, back of the cylinder head, near the inlet of the water pump and just at the inlet/outlet of the heaters.
The idea, sometimes, is to place valves so that parts of the heaters can be isolated - in case of a leak, from the rest of the system and leave the bus operational.
good luck, be methodical, perhaps map out coolant lines as an aide.
william
