11-06-2020, 06:08 PM
#41
Year: 1972
Engine: GMC 5500 V-Eight
Rated Cap: 48
Originally Posted by peteg59
I realize you mentioned earlier that the engine wasn't seized.
While its possible something in the trans has failed, I would double check the engine's rotation by hand.
As long as it turns over that way, since it has now been found to be "sitting" 7~8 years, I'd highly recommend removing the spark plugs and squirting some Marvel Mystery Oil in the cylinders. Let it sit 24 hours or so, and then try turning it over on the starter to more evenly distribute the lubrication in the cylinders.
If the trans is truly locked up, a teardown is in order.
Good luck on your new project, and post up pics as you go...
The engine turns fine. However, even if it didn't, it wouldn't change that there is an issue in the tranny for sure because it doesn't come out of gear... even though the shifter is in neutral.
It's possible it's just dry... Just in case anyone ever says I don't have a positive outlook lol
11-06-2020, 06:10 PM
#42
Engine: 345 international V-8
Tranny could be stuck in two gears at once. Does the gear shift move normally ? With clutch in shift into each gear and see how it moves. No need for the engine running to do this. If it is stuck and will not move take the shifter cover(and gear shift lever) and see if the shifting rails all line up when in neutral.
11-06-2020, 06:12 PM
#43
Year: 1972
Rated Cap: 48
I didn't spend a lot of time playing with it earlier, I was just trying to get it to move... but there is something weird in it's shifting that I want to check out. It never gave the feeling of actually switching gears at all. Some resistance as in, it's not doing 'nothing', but I don't think its doing what it should. I'll play tomorrow.
11-06-2020, 06:24 PM
#44
It does sound like the shifter has jumped out of the shifting rails by what you say. Could also be a shifting rail stuck and a pry bar and some oil is needed to bump it around, this would be done with the cover off. Just do not get to happy with a pry bar in there....gentle is key.
11-06-2020, 06:34 PM
#45
Year: 1972
Rated Cap: 48
First things, first... lol Tomorrow I'm swapping a good battery in and seeing what happens. I have no clue what's hooked up, what's not, what's shorted... lol
Then, we have to clean the damn thing out, because it's full of... 'stuff'.
After that, (which may not be tomorrow), I'll start seeing what I can find out about the engine and tranny. Likely going to have to remove the hood, the hinges are solid on it and the hood itself is falling apart. I tried to get into it to take a video earlier and get the numbers off it, but it wasn't happening.
11-06-2020, 08:32 PM
#46
Oh and actually I heard a different story today than the one I... 'thought' I remembered from last time...
The bus hasn't run in likely 7 or 8 years... not a year as I thought I was told last time.
The rear tire is not seized, none of them are. Something in the tranny is locked though. With the clutch engaged, the tires turn fine.
if the rear tires (along with the driveshaft) turn with he pedal pushed down then nearly everything in the trans is turning but the input shaft.
I'm thinking maybe with it sitting for so long that the clutch disc is rusted stuck to the flywheel.
Is the shifter stuck??
11-06-2020, 08:39 PM
#47
Year: 1972
Rated Cap: 48
Doesn't seem to be, but that was part of what I meant when I said it didn't feel right, I'm not sure if it's moving into positions properly or not as I really have no idea how far the are and there's no feeling of engaging or disengaging.
11-07-2020, 09:36 AM
#48
Engine: Cummins 24valve 5.9
I had a 71 Chevy with a Thomas body as my first bus. It was super easy to work on except for the brakes, they were a nightmare. Mine also had a 350 and an sm465. I didn’t drive it much 60mph was top speed at about 4500rpm if I remember right. All engine and trans parts are easy to find and cheap. Brake parts were extremely expensive if you could find them. Hopefully some inspiration or you
11-07-2020, 09:59 AM
#49
Year: 1972
Rated Cap: 48
Heading back out again in a moment, found this so far.
11-07-2020, 10:10 AM
#50
Year: 1972
Rated Cap: 48
and this one
11-07-2020, 10:28 AM
#51
Year: 1972
Rated Cap: 48
Still looking, figured I'd share these.
11-07-2020, 10:30 AM
#52
Year: 1972
Rated Cap: 48
Also, this is my neighbors bus that I get to see every day I walk outside lol
11-07-2020, 11:48 AM
#53
Year: 1972
Rated Cap: 48
That firing order is pretty typical of 99% of Chevrolet V8, though. Doesn't differentiate a tall deck 427 from a 283 or most of the others. Casting number will tell the tale.
Originally Posted by Jolly Roger bus 223
i cant remember exact location but the firing order will be cast onto the intake manifold
but if it is a 350 and if i remember correctly?
the firing order is 18436752
Hard to make them out right now, I'm cleaning them up a bit and will check again, but for now.
11-07-2020, 12:57 PM
#54
Year: 1972
Rated Cap: 48
Okay wth?
I can't find the suffix TND anywhere...
11-07-2020, 01:00 PM
#55
Year: 1972
Rated Cap: 48
Okay wth?
The rest is Flint, May 6th I believe?
11-07-2020, 01:21 PM
#56
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
350 casting number should be driver's side rear, topside bellhousing area.
11-07-2020, 01:30 PM
#57
Year: 1972
Rated Cap: 48
I know where it is supposed to be, it either isn't there or I still have some more layers of crud to get through lol
11-07-2020, 01:37 PM
#58
Year: 1972
Rated Cap: 48
The hood is now off, so I'm getting closer lol
11-07-2020, 01:59 PM
#59
Year: 1972
Rated Cap: 48
Hey! Look what I found.
11-07-2020, 02:01 PM
#60
Year: 1972
Rated Cap: 48
3970014....350...70-76...2 or 4
I still don't get why I can't find the tnd suffix though. All the lists and sites say they aren't complete lists, but none of them point to any that are.
