Old 07-28-2021, 06:19 PM   #1
Howdy, and a question about fire suppression system
Happy to say I finally joined your ranks after lurking for a couple years.
Just got my first project: a2006 E350 cutaway with a 5.4 V8. It's small and high mileage, but it was cheap and I'm gonna practice on it before I decide if I wanna go big.
As I'm clearing out the interior, I was wondering if anyone had any experience removing the fire suppression system in their bus to gain some storage space. I'm pretty confident in my demo thus far, but I'm a little skittish about unleashing the power of a massive tank if I do it wrong. It's a pretty common design as far as I can tell, with the tank right near the entry door (see pix). Any ideas?
Thanks ahead of time!
File Type: jpg 5D0D77AC-BE14-4D43-B7AD-1FD85E168D3C.jpg (300.9 KB, 12 views)
Jgcfritz is offline   Reply With Quote
Old 07-29-2021, 11:04 AM   #2
shaymcquaid's Avatar
Chassis: 40' MVP-ER
Man! I'd leave it!!!
shaymcquaid is offline   Reply With Quote
Old 07-29-2021, 11:48 AM   #3
Engine: C7 Cat
Hello and welcome.
Yep I agree, doesn't look like you're going to gain much space for taking out what someone obviously thought was a very useful safety device.
Cool feature and likely was an expensive option.
Cheers
Oscar1 is offline   Reply With Quote
Old 07-29-2021, 11:49 AM   #4
Engine: C7 Cat
P.S. If you do decide to take it out you can always recycle it by sending it my way
Old 07-29-2021, 11:53 AM   #5
^^^ Forget this guy - I'll come get it!
Old 07-29-2021, 12:19 PM   #6
That's funny, I thought of it as a good idea for safety in a bus full of kiddies, but overkill for a schlub like me. Maybe I'll leave it, but I'm not even sure if it works or how to test it... Or if I even should.
Thanks for your thoughts!
Old 07-29-2021, 12:21 PM   #7
Even a schlub is going to be pretty depressed when his bus burns to the ground after putting years of work into it. But hey, you could put an umbrella stand there instead!
Old 07-29-2021, 12:39 PM   #8
Race cars have them accidently go off all the time, make huge mess.
Old 07-29-2021, 01:10 PM   #9
Spent 18 years racing NASCAR, never seen a system discharge accidentally. They are filled with a gas, they make no mess or leave a residue.
Old 07-29-2021, 01:13 PM   #10
Engine: C7 Cat
This is a boat engine compartment fire port.
It allows you to confirm fire without lifting the engine cover and introducing more oxygen and then the slit allows you to poke an extinguisher through the port. Might be real handy in our builds to put them in the electrical closets.
Cheers
Old 08-04-2021, 11:15 AM   #11
Chassis: 40' MVP-ER
Attachment 59949
Cheers
Thank you. AWESOME!
Old 08-04-2021, 02:36 PM   #12
Coachwork: Blue Bird All American
Rated Cap: 2 adults and two pigeons
Thanks Oscar, that’s a great idea!
--Simon
Found my Bus at AAAbus in Phx!
Bus'n it is offline   Reply With Quote
Old 08-04-2021, 03:46 PM   #13
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
I'd probably pull it out unless it ONLY goes into the engine compartment (or you can modify it to only disperse in the engine compartment) and uses NON CORROSIVE gaseous or dry chemical media.
Gaseous or dry chemical systems dispersing into a passenger compartment can KILL through a number of mechanisms.
Corrosive media disbursing into your engine compartment will likely result in a totaled vehicle. Yes it might stop the fire but corrosion will rapidly destroy things.
You should also check the servicing costs and interval. Pressurized vessels require testing or replacement which can be prohibitively expensive.
It would be nice to have an effective and reliable built in fire suppression system but be sure you know all the variables before deciding to pull it, leave it, or modify it.
We've done so much, for so long, with so little, that we can now do the impossible, overnight, with nothing.
The United States Marines, America's 911 force -- 6531, 3521 '79-'99
Retired mech (auto/aviation), Extra Class HAM, NAUI/PADI OpenWater
HamSkoolie is offline   Reply With Quote
demolition, fire extinguisher, fire suppression
