08-11-2017, 11:11 PM
I did it now I have an air door question
Has anyone come up with a way to secure the air doors? I have bought a 98 International 3800 DT466E. I'd really like to keep the doors but I don't want to use a padlock. I'd like to be able to lock it from the inside as well as the outside, has anyone come up with a solution they're using?
08-11-2017, 11:32 PM
How cool is that - I'm in Prince George, Va. Thanks for that I'm picturing that on the inside of the door that overlaps on the outside - and a locking handle?
08-11-2017, 11:36 PM
I'll post pictures of hardware.
08-11-2017, 11:58 PM
Sorry had to use Google Drive.
http://www.skoolie.net/forums/showthread.php?t=18837
The "D" handle is inside, "T" handle is outside.
2 long rods get fitted to pins that rotate moving rods up n down.
08-12-2017, 12:06 AM
08-12-2017, 04:26 AM
This is where I first saw the Atlantic shed latch used, in a video posted by this skoolie builder.
https://www.facebook.com/LeDiableRougeBus/
08-12-2017, 06:03 AM
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
My Bluebird has a factory-installed lock. I don't know where you would get it but it basically is a pin that is cable-actuated to the top of the door with a lock cylinder on the outside of the door. I have a latch on the inside to keep people out when the door is locked from the inside.
08-29-2017, 08:46 PM
Chassis: 9 window handy bus
Rated Cap: 18 and 2 wheelchairs
Newbie
What about lock for non accordion doors....the two panels centers swing out? 98 bluebird handi bus
08-29-2017, 10:20 PM
Chassis: Bluebird
Rated Cap: 72 pax
My doors are 2 panel swing outs. They overlap and are mechanically connected. If one is locked the other won't open.
08-30-2017, 04:17 AM
Year: 98
That is similar hardware as I used in Elfie. Up-cycled from the junkyard. :smile. Made a cut in the lowest door step and bend the lip down as to get more resistance against wear through vibration.
Later j
09-06-2017, 06:43 PM
Coachwork: Crown / Pusher
Just a word of advice, When you start your bus MAKE SURE the switch for your door is in the open postion before stepping out while waiting for things to build up. I once started the bus & stepped out & a few minutes later was walking back & the door was about 3/4 closed & had to use all my strength to hold the door enough to squeeze thru, Another member a year or so ago did the same thing only his door was closed when he got to the door, I think his bus idled for a couple days while trying to figure out how to get in .
09-06-2017, 06:53 PM
Chassis: Bluebird
Rated Cap: 72 pax
OMG I did this the very first time I started it and the air had to build up... Luckily I had the emergency exit unlocked. Good tip!
09-06-2017, 07:01 PM
Mine also except The bus was backed into its parking spot sot the rear door was only 5 inches away from the fence.
09-06-2017, 10:13 PM
Engine: TE 444
Rated Cap: 12
factory air door should have an override switch that "unpowers" the door so you can close it manually while the bus is running
09-06-2017, 10:15 PM
Yes, on mine it's the same switch, 3 position, on the dash.
09-06-2017, 11:07 PM
Engine: TE 444
Rated Cap: 12
well my only experience with air doors was eagles or MCI's, the override switch was in the stairwell by the door
09-07-2017, 07:12 AM
if you have an air door can you get underneath and let the air out of the tanks to gain entry?
09-07-2017, 07:51 AM
Chassis: Bluebird
Rated Cap: 72 pax
They take a lot longer to leak down on my boss then the tanks. And if the engine is running I don't know if you could keep up with it.
09-07-2017, 07:55 AM
true they probably have a check valve. I know on mine if I open all 3 tank valves i can definitely drain more air than the compressor can pump.. at least at idle.
