I finalt pulled the trigger
And put money down on a 2008 bluebird 30 ft bus that was used for a school for the blind. it has 20 ft behind the drivers seat. it has a commins 6.7 turbocharged
engind allison trany. 150,000 miles az bus no rust tonney will remove the seats and rear heater . and give me a roof hatch.
the bus has a front and rear camera already. he will also remove the stop sign all decales chang lenses on front and rear flashers .
I have found a spot to work on it with power but its outside and its 110 degrees or more in AZ at this time.I plan to use bus air during build!
Almost forgot he will also pull up the rubber floor. Its an AZ bus ill leave the plywood. Im going on 77 so a can of cheap paint will outlast me and im fine with that.
