02-11-2018, 01:40 PM
#141
Originally Posted by plfking
I remember seeing this at a trade show when it first came out, and wondering just how big the inventor's balls were when it came time to prove the concept.
I used to work with a guy that had his fingers saved by this device.....not just once, but twice over a 5 year period. I *think* he was fired after the second occurrence.
He didn't need balls, he used a piece of sausage.
02-11-2018, 02:35 PM
#142
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
I put a lot of faith in technology- my car, for one. I just could never be convinced of that level of trust.
I used to run a cnc machine in a cabinet shop & one of my duties was to make templates for the shaper guy. Tough, old Mexican dude missing tops of 3 fingers. A shaper is 5-hp router table w/ a spinning bit the size of a baseball that he'd freehand-feed wood into. Cajones.
I asked him what it feels like when the blade removes the fingers- he said it feels real hot- heat sensation.
02-11-2018, 03:43 PM
#143
Rated Cap: 34
Same here. No matter how much I KNEW it would work, there's no way I could have finally stuck my finger in there.
Would've probably tried to hire someone to do it......wonder how much that would have cost?
02-13-2018, 04:13 PM
#144
I can go both ways on the SawStop. No argument that it improves safety. But, the guy who invented it lawyered his competition (a garage inventor - one man band) out of business, and lawyered his contraption into the EPA regs. I don't like people who work like that.
His solution adds several hundred dollars to the cost of the saw, and you have to buy it from him, which is hundreds more. The competing idea was an electronic box that used back EMF to stop the motor when something the temperature of a live human was detected within an 1/8th inch of the blade. Granted, it took 100-125 msec to stop the blade, but would you wear a band-aid in return for not having to buy a replacement shotgun cartridge for $70 plus a new sawblade? Not to mention having to buy a new table saw to get the safety device in the first place.
02-13-2018, 04:52 PM
#145
That saw wouldn't work in anything over 97° weather, i'm sure the teeth get hotter than that in seconds after cutting. Theory doesn't sound viable.
02-13-2018, 05:19 PM
#146
Good point. I'll see if I can get better info from the source. I've got it bookmarked at home. Perhaps it's a break-the-beam type of thing, but I seem to remember that it could discriminate between a finger and a screwdriver (and material being pushed through the sawblade).
02-13-2018, 08:27 PM
#147
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
Talking about belief in your product weather its true or not I saw a video of a guy drinking the effluent from his septic tank to prove how well the treatment system worked did not have a chlorine injector on it.
02-13-2018, 08:37 PM
#148
And we honor him postimously for believing in his product.
Robin
Nobody's Business
02-25-2018, 08:48 AM
#149
Coachwork: Never coached any teams, not even junior soccer
Chassis: I'm still figuring out what this means
Engine: CAT diesel
Rated Cap: No caps, only hats.
Skoolie Q&A
My perspective on a few things Skoolie related: screws and fasteners, insulations, and wiring decisions.
02-28-2018, 09:20 AM
#150
Would've probably tried to hire someone to do it......wonder how much that would have cost? [emoji2]
That depends on how hard they tweaking...
03-04-2018, 09:56 PM
#151
Engine: CAT diesel
Cargo Box Transplant
Having pulled these cargo boxes down to make room for my black tank, I ended up transplanting them to another place on the bus.
In my experience, under-bus storage is never completely dry when driving in serious rain, so I'll likely use them for things that can get wet: the RV dump hose is down there now, but my dream is to store tools in tubs down there one day.
05-27-2018, 10:23 PM
#152
Engine: CAT diesel
Prison Bus Video #31 is Live
Did a bit more work on the prison bus ...
06-11-2018, 02:05 PM
#153
Engine: CAT diesel
Folding Couch for the Prison Bus
An overview of how I built my flipping folder of a couch. Plans should be up soon for those who like such things:
06-14-2018, 05:41 PM
#154
Engine: CAT diesel
Plans for Folding Plywood Couch
Hi all,
I drew up some plans for the folding couch I posted about last time:
https://etsy.me/2t7JLpi
Spencer
07-05-2018, 09:09 PM
#155
Engine: CAT diesel
New Video Up ... Receptacles and Other Finish Work
Tuned up the receptacles and switches on the prison bus ... starting to feel like home.
07-14-2018, 04:33 PM
#156
Engine: CAT diesel
Sliding Barn Door and Drawers on the Prison Bus
07-14-2018, 06:51 PM
#157
What didn't work on the door?
07-14-2018, 06:58 PM
#158
Engine: CAT diesel
joints
The joints just weren't as tight as I was hoping for ... I think I've gotta use router bits or chisels from now on. On the table saw, the tenons just end up too messy.
Next time!
07-14-2018, 07:09 PM
#159
Biscuits and glue?
07-14-2018, 07:28 PM
#160
Engine: CAT diesel
Biscuits and glue?
I should have gone that route, as my biscuit joiner usually dials things in really well! Instead, I was trying to do grooves and tenons ... dang imprecision caught up with me!
