Originally Posted by Jolly Roger bus 223
welcome.
for the cooling issues.
have you cleaned and flushed the radiator?
is your fan kicking in?
plenty of good clean fluid?
Thanks for the tip! I am waiting for a new thread to be approved to help with diagnosis, but:
Drained, flushed, and refilled with Green+DCA and new coolant filter with DCA as soon as I got the bus. It had been occasionally run and sitting for ~5 years.
I can't tell if the fan is kicking in or not. I've read you should be able to hear it "roar", but I haven't noticed a big change in air/fan noise as it heats up. Opening the doghouse is quite windy. Someone gave the tip of getting it good and hot, turn it off, and the fan shouldn't be able to be moved by hand much if the fan clutch is working as it's supposed to. I haven't been able to try this yet.
The Radiator had a small (1/2") fracture/crack near the top which I brazed and JB welded over (first time brazing ever...). It seems to be holding up well, but makes me wonder if there are other small system leaks. Am I correct that if the system can't build pressure, it won't be able to circulate coolant? Or is that only the case if the leak is engine-side?
