Originally Posted by Chiki Toka
Hello from Charlotte, NC!
I’m just getting started researching skoolies and other conversions to see if it is doable for me. I’m so intrigued by the nomadic life, and my cat doesn’t care where he is as long as he has food and a lap to sleep on. No worries there…
One HUGE problem is that I am a paraplegic and in a wheelchair. Not only am I unable to do the work myself, but I also need extra consideration in the design with more “bells and whistles” than the average user.
I am certainly aware the process will take a LONG time, and I think I have enough patience. It’s the matter of cost. It may end up that I am better off buying a used RV already adapted. We’ll see.
All that said, I’m happy to have found a forum where I can search for answers to my many question, and rely on the advice of those who have already “gone rogue”.
Thanks, Chiki Toka
Welcome to the forum and a fascinating project. I am just as interested in living off the grid as I am in being mobile. I feel strongly that (if done correctly) the DIY schoolie path is the better path. RVs simply are not built to last for full-time living like most schoolies are.
RV's are barely built to last occasional recreational use, and much of the damage is not in using it, it's simply in transporting it from one place to the next.
Without any hesitation or doubt, I would do a proper bus conversion with wheelchair access over an RV every time. I am also money-strapped, but this is a time for life-preserving priorities, not penny-pinching.
Sometimes RVs are cheap but they also don't last very long, so if you happen to get a good enough deal on an RV, I'd still be planning on it eventually failing and looking to do a custom schoolie as soon as you can afford it and sell the RV.
I suggest expanding your perspective, try to not let the fear of not having enough finances get in the way of important decisions. Time and positive spirits have a way of changing things for the better.
But if you go with an RV deal, it could cost twice as much within the first two years because of likely repairs and possible breakdowns.
This is your "house and home" and it protects the most important thing around,,, "you're life". Maybe consider spending a little more on your rig than you are presently thinking to reap the benefits of years and years of reliable service, instead of repair after repair and frustration after frustration.
Remember, when you are living mobile and you happen to break down in the middle of nowhere, suddenly having a more reliable vehicle becomes a must-have priority.
It's not just for the rich,
you "need" something reliable. Let's just hope it's also affordable, or you will be taking on some debt. Local Churches like to help those in desperate need, and your need would qualify and "might" generate funds you are not expecting.
Don't forget the long term because if you don't, the short term probably will punish your long term. ;) It pays to plan the future out well.
Bravo on taking on such a project. Wishing you the best!!!
