Glad you made it back and saw our posts. Since you live in the SoCal area I strongly suggest that you email me and I'll get you in direct email and phone contact with John so he and/or I can come see your Crown and give you the answers you seek. John's the man for Crown II's and he'll help solve most all your problems.
For instance, the air ride is most definitely tied into the aux. air system and comes up after the primary is aired up. There can be problems with the check valves, for instance, or the air-ride leveling valves could be giving you trouble and not letting the aux system fill up, many things could be impacting this, and not all are very big problems or even expensive to repair. Only needs a little troubleshooting and isolating the problem component(s). And again there are NO electrical components in the air system except for warning switches. If it's riding real HARD and bumpy it definitely sounds like the air-ride isn't coming up and needs attention, most likely a leveling valve problem. They aren't expensive at about $50 now and you can get them all over the place.
I'm a little surprised you can even release the parking brakes if you don't have the 90psi it usually requires. Sounds very interesting and needs to be looked at to find the underlying problem. Probably shouldn't drive it much until you can get this repaired.
Asking for help here is not an efficient use of your time and won't produce anything but the most generic and unsure answers to your specific issues. No insult to the folks on this forum but I suspect they would be the very first to agree that they probably aren't the best source for the expert help you need specific to Crown II's.
Even my experience is not as broad or as deep as Johns is on the Crown II's. I can help with the overall Crown questions but he will give you the laser focus on the Crown II. Take a deep breath and pause in your efforts to open things up and find what's wrong, We can help you with that and also offer specialized shops in case we can't find the faults. John and I can probably do in a single afternoon what you've been struggling with for the last few months. Lets meet at your bus.
Contact me asap and we'll help you find the answers you need.
mikemcc2k@yahoo.com
