Old 10-02-2021, 12:55 PM   #1
New here!🥰
Hello all!👋
Roy and Tammy here! A Couple Adventurers’!
So we finally bought our bus and started reno!
Gracie, she’s a 2010 International DT466
Here’s the thing! I disconnected all the emergency doors and windows and I thought I had grounded all the wires, now she has her parking brake locked!
She turns over but will not move because of the brake!
How do I fix this?!?
Thx, T
ACoupleAdventurers is offline   Reply With Quote
Old 10-02-2021, 01:35 PM   #2
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
What about the 'No child left behind" system. What has been done with the reset button in the rear?
Disconnected? Unplugged above the window or in the fuse panel? Not cut wires, right?
Old 10-10-2021, 03:16 PM   #3
I don’t know what any of that means! ��
Old 10-10-2021, 05:32 PM   #4
Engine: Navistar 7.6L
SeeHere
At the back of the bus is a switch or button that must be pushed for 3 seconds or so after ignition is turned off. This is to force the driver to go all the way to the back of the bus before leaving the bus.
Doing so, there is a better chance they will notice a child sleeping away.
If not pushed, an alarm and horns come on.
Maybe if not pushed in time it also opens shuts off air to the brakes?
Don't know what all it does, but then I did not stay at a holiday inn express last night either.
DoubleO7 is offline   Reply With Quote
Old 10-16-2021, 12:55 PM   #5
@DeMac
I have disconnected all those wires and ground them.
I will check that button amd see if that may be the problem.
Thanks!
brake locked, emergency door, emergency exit window, parking brake
