Originally Posted by dzalinsky
Thanks it too a while to find around my area. Paid $5k for it 181k on the dash.
My main concern about the trans was taking it on trips around the country and flat towing behind it. While driving it home it wasnt happy with the hills on the highway. Thats a major safety concern of mine.
Where in Jersey? I'm in near Lake Hopatcong.
Did you buy the bus in Jersey? If yes, did you crawl under it to check for rust?
181,000 on a DT466 is just getting started assuming it's been properly maintained.
Re. the 545, there are folks here that run them and know how to keep them healthy for as long as possible. If yours is healthy then you may as well take care of it and get as much use out of it as you can before you go through the work and expense of swapping. I assume one or more of them will comment when they see this thread.
In terms of your drive home, it's possible problems in hills had to do with rear end ratio as much as with the tranny. Without knowing more about your experience it's hard to be sure of anything.
