Originally Posted by Ourvanlives
Just wanted to introduce ourselves. We're retired/disabled couple and been wanting to get started into the Skoolie life for a couple of years now. Another 18 months and we'll have our house paid for. Then we can start saving up for our Skoolie. Been window shopping for things on Amazon along the way and saving them in lists of what we want/need for the conversion of the bus. We're thinking about either a mid sized bus or a shuttle bus. We like the wheelchair lift to be near the front door. But not many of them out there like that. Did they only make them for a certain period of time or a certain company make it there?
it was often up to the school Spec.. I do know quite a few of the mitchell built carpenter body busses had them in the front.. (mine did).. but finding a mitchell capenter in good shape is likely going to be tough as I think 1995 or 96 was their last year..
the rear was the most common as it meant the wheelchairs could be loaded into the back with the tie downs.. and the bus could have regular full width seats up front.. in my bus the bus seats are narrow so that the chairs could roll to the back where some of the tie-downs are.. so the capacity was greatly reduced..
some schools asked for up front lifts so the busses are out there.. just not as easy to find ..
the other thinbg to think about is if you both require being lifted into the bus, that you may need to have a bus modified so that the lift can be used from the outside.. mosrt of them require that you deploy the lift from inside the bus.. manually open the door and then bring out the lift.. unlike an actual handicap van thats designed for you to be lifted into from the outside...
