Old 09-28-2021, 03:17 PM   #1
Paint prep for plugging up head/taillight cutouts
In nearing the end of sanding and minor body work. I’m interested in ideas on how to plug holes and cutouts where reflectors, running lights and headlamps/taillights fit in. I’m thinking styrofoam cut to fit, but who has a simpler effective idea?
Arlo is offline   Reply With Quote
Old 09-28-2021, 03:26 PM   #2
Tape and paper?
Old 09-28-2021, 06:13 PM   #3
Bondo + these patches. But probably only good for holes up to the size of a quarter. Anything larger (like headlight holes) you want to either weld in patches of sheet metal and bondo the seams or rivet larger patches over the opening.
Are you going to be driving your bus without headlights or taillights?
Old 09-28-2021, 06:19 PM   #4
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Think he's talking temporarily while painting.
peakbus is offline   Reply With Quote
Old 09-28-2021, 07:41 PM   #5
I guess, but why would you need to do that?
Old 09-29-2021, 06:23 AM   #6
I put rubber grommets in a lot of the holes I had for smaller things like 2 way antennas, stop sign wires, etc. for screw holes, little bit of clear silicone like flex shot and well simply a stainless steel screw.. keep it simple
for anything im putting back I purposely painted the hole as it would then be coated for protection
Old 09-29-2021, 03:46 PM   #7
Thanks to all responders
Thanks for your answers to my question about how to handle the openings left when things like flasher lights, taillights, etc are removed for painting. I thought maybe I’d be removing the “plugs” after the primer coat and reinserting them before the finish coats. I was thinking of something reusable (like styrofoam). But perhaps just painting right over those openings would be ok and would certainly be easier and time saving.
Anyone see why spraying into these open areas would not be ok?
Thanks again!
Arlo
Old 09-29-2021, 04:25 PM   #8
I just sprayed over and around those openings and there were no problems. I got a bit of paint on the wires and whatnot but it doesn't matter.
