Old 12-14-2020, 05:37 PM   #1
Coachwork: Thomas School Bus
Chassis: Westcoaster ER
Pre-fill or Not to Pre-fill
So I'm going to change the Fuel Filters on my CAT 3116 and I'm torn between Pre-filling the filters or not. CAT says don't Pre-fill but mechanics say DO Pre-fill them. Any advice on this topic anyone?
Cruzer is offline   Reply With Quote
Old 12-14-2020, 05:56 PM   #2
Don't prefill. But if you must- fill with a plug in the center so you fill the filter side only.
Old 12-14-2020, 06:01 PM   #3
Coachwork: 44' Newell Coach
Engine: 8v92T Detroit
Rated Cap: 2 adults and two pigeons
I put them in dry and add the equivalent oil of the filters capacity to the crankcase. I do lube the gasket on both sides though.
--Simon
Bus'n it is offline   Reply With Quote
Old 12-14-2020, 06:03 PM   #4
Yeah, the oil filters on cat go on empty, too. But op is talking fuel filter, fwiw. Cat also says put those on empty.
Old 12-14-2020, 06:32 PM   #5
Chassis: International 1753
Engine: 6.9 International
This mechanic follows the oem's, and doesn't prefill filters.
There are a few examples where I do, because there's no way to prime the system by a hand pump or activating the electric fuel pump.
But those are rare cases.
Old 12-14-2020, 08:07 PM   #6
bus-bro's Avatar
Engine: 3208 na boat anchor
I always fill them with filtered fuel, maybe just a habit. On engines that self prime it probably doesn't matter. And when you pre-fill the filter you can introduce contaminants into your fuel system.
Nonetheless, I always pre-fill the fuel filters. Lube oil too, if possible.
Old 12-14-2020, 10:04 PM   #7
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
It is best to not prefill the filters as it could send contaminates directly to the injection pump and injectors.
It is ok to prefill if you plug the center hole of the filter when you add fuel. I use threaded plastic plugs that came out of the ports of some hydraulic valve I bought. I have a truck with a C15 that even with a brand new hand priming pump installed will take forever to start unless the filters are prefilled.
An engine with an electric lift pump shouldn't need to be prefilled. Turning the key on and letting the lift pump run for a while before cranking the engine will prime the system. Some engines like the ISC with CAPS may need the key cycled on and off a few times as the electric pump only runs for around 30 seconds and then shuts off.
Ted
