Need more info.
The 9.0L is okay. Not a highpowered rig by any means, but it will be reliable enough so long as it has the updated head gaskets. It's non-turbo'd so don't expect modern turbo diesel power from it. 180hp or so is all you'll get.
You listed it as an automatic trans. I assume it's an allison, but the model of allison is pretty important, as some are less reliable and desirable then others.
A lot of guys have converted old buses into race car haulers. There's a few builds on here showing that. Most have used ramps and a flat deck on the frame rails. Some have floated the idea of using a roll-back wrecker bed, some have also floated the idea of a lift gate like a modern toterhome, but I've never seen either concept become reality.
If you're a good fabricator, the only limits you'll have is money, time, and imagination.
