Old 03-17-2023, 04:55 PM   #1
Whiskey.Wilderness's Avatar
Rated Cap: 29000 GVWR
01’ International 3800 - Hitch/Wiring - TOAD QUESTIONS
2001 International 3800 Dog Nose.
Buying a wrangler and know what flat tow system we want to get for it but we don’t know what wiring harness or hitch to get. Anyone else tow with their 3800 dog nose?
Would love some links to the products you used.
Thanks
WHISKEY WILDERNESS
DRINK WHISKEY, LIVE WILD
Whiskey.Wilderness is offline   Reply With Quote
Old 03-17-2023, 05:23 PM   #2
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
Thanks
I'm in the process of putting a tow hitch on my 2006 IC conventional. If you've swapped out all the lights for LEDs you can probably get away with tapping into the brake and turn lights in the back. Run a dedicated line from the battery (on a fuse of course with the right gauge wires) for the auxillary power. If you're still running incadescent lights you should probably run fresh wires from the relay in the fuse box with the correct gauge wiring and fuses.
I did a CURT 14082 Class 4 Trailer Hitch. It's a pretty generic width that fits most bus frames, you just gotta measure.
https://www.amazon.com/gp/product/B0009X9F72
TSLABUS Build thread:
https://www.skoolie.net/forums/f11/j...ert-38328.html
TSLABUS YouTube Channel:
https://youtube.com/@thetslabus
Dbacks2k4 is offline   Reply With Quote
