Old 04-09-2017, 12:31 AM   #1
7.50-20 tires available?
I found an old bus (1966 Ford). The seller says it needs all new tires (6) and the size is 7.50-20. After a little research, it seems this size is no longer made. I did find a site where you could order them from China so long as you buy a minimum of 100. Is there any alternative or should I forget about this bus? What are the common sizes for bus wheels these days. The Firestone site only lists 22.5.
Gazolba is offline   Reply With Quote
Old 04-09-2017, 03:05 AM   #2
7.50x20 is an old and obsolete tire size for a smaller sized bus.
You might be able to find some 8.25x20 or 9.00x20 that would fit your wheels.
If you have spoke wheels it would be relatively easy to upgrade to a tubeless tire and wheel.
If you have the 5- or 6-lug wheel it will most likely be very difficult and expensive to upgrade to a tubeless tire and wheel. About the only places I can think of that might be able to help you with finding tubeless replacement wheels would be Stockton Wheel or Six Roblees.
Stockton Wheel
Six Robblees' Inc. | Since 1913
Old 04-09-2017, 04:13 AM   #3
My 1974 C60 BB has 6.5 x 20 2 piece wheels. I want to change to tubeless tires. I have been quoted 370.00 ea cdn to replace the wheels then tires on top that. I have found Accuride wheels (same as quoted) at half the cost + shipping. Exchange rate makes the price work out the same.
Hope this helps
Gordon
Tootalltechie is offline   Reply With Quote
Old 04-09-2017, 08:44 AM   #4
I priced out 6.50 x 20's for my '46 before I swapped axles at $200 each through a big rig tire shop here in Houston.
Wound up with 19.5's but they are tubeless radials. All the 20's are bias ply, tube type.
Old 04-09-2017, 10:03 AM   #5
Engine: Navistar 7.6L
Tire Rack has 27 different
20" tubeless radials .
But only up to load range E.
If they are the split rim type you might as well figure on getting newer rims.
Most tire shops refuse to work on split rims.
DoubleO7 is offline   Reply With Quote
Old 04-09-2017, 10:51 AM   #6
Robin97396's Avatar
You could get them delivered.
(6-Tires) 7.50-20 tires Hi-way Express 10 PR tire 7.50/20 Samson / Advance 75020 | eBay
There seems to be many 7.50 20" tires online. I couldn't find anything specific to your area because I can't tell where you live.
Robin
Nobody's Business
Old 04-09-2017, 10:58 AM   #7
2kool4skool's Avatar
Phoenix AZ
Don, Mary and Spooky the cat.
Old 04-09-2017, 11:29 AM   #8
Robin97396's Avatar
In Phoenix there seems to be a lot of used or vintage tires in your size. Some come with wheels, although I'm unable to tell what kind of wheels.
For new tires I think you'll have to have them delivered. This is a common size tire for old farm trucks. Both the 7.50 and the 8.25. In my experience these sizes are usually bias ply.
https://www.cokertire.com/
https://phoenix.craigslist.org/cph/wtd/6077076633.html
I've bought sets of wheels from the truck junk yards for my '72 Ford shorty at $50 per wheel. Occasionally a junk yard wheel will have a half decent tire on it, but they like to charge extra if there's any tread remaining on the tire.
I like the solid wheels much better than the split rim. I was never able to get a cage for inflating the split rim wheels and I got tired of wrapping chains around the wheel for safety during inflation, so I switched to solid rims.
Robin
Nobody's Business
Old 04-09-2017, 11:59 AM   #9
Make sure you do NOT have any split rims. Safety ring rims are easy enough to work on, but any true split rim can be deadly. The most notorious was the Firestone RH5. I only press this issue because they can often show up on vehicles which originally never had them. Like my '46 Chevy, for example. I discovered that one of my inner duallies had been replaced with one such RH5...also known as a "Widowmaker". And for good reason.
Play safe out there.
Old 04-09-2017, 12:24 PM   #10
Robin97396's Avatar
For any of you that don't understand the dangers of split rims, if the split ring is not seated properly it can shoot of the tire as you're inflating it at a velocity that can take a man's head off if you're in the wrong position near the tire. They have also been known to throw a man 13' or more into the air if you're standing on the wheel when the ring comes off.
Tire shops have a heavy duty cage to put these split rims into while inflating them to prevent such injuries. You can use numerous loops of heavy chain wrapped around the tire and wheel during inflation for safety.
Many times it is nearly impossible to break the bead when trying to change tires. You may feel that $35 is well worth having someone else change those tires.
Robin
Nobody's Business
Old 04-09-2017, 01:13 PM   #11
Chassis: chevy
Engine: 3116 catapillar
Rated Cap: formerly 71 now 2 or 4
if you find someone to work on this split rim wheels sometimes they will get them apart and find that the rust is so bad they can not put them back together (osha rules here) and you will be buying new rims split rims and tube type tires are still available but not common so carry a mounted spare or convert to tubeless talk to truckers about tube type and you will find out why we dont run them anymore and carry a big fire extinguisher if you do
mmoore6856 is offline   Reply With Quote
Old 04-09-2017, 02:14 PM   #12
I've done hundreds of 24" split rims w/o a cage. If you're doing a three piece always buy and install new lock ring. Clean off the rust on the rim and the safety ring. I inflated them flat on the shop floor with a clip on chuck. When the rings did come off it was always less than 50 psi. The air hose kept them from going far.
Clip on air chucks, the push on kind, are your best friend working with split rims.
WVDarren is offline   Reply With Quote
Old 04-09-2017, 02:35 PM   #13
Chassis: chevy
Osha requires a cage many guys died doing it your way
Old 04-09-2017, 06:07 PM   #14
You're correct except WV is not an OSHA state. OSHA doesn't say boo in WV. There were nights I had to mount thirty+ tires. I often had three laid out flat being aired up at one time. The upside is that the wheels and safety rings had been refinished and the liners, tubes and lock rings were new.
Old 04-09-2017, 07:20 PM   #15
Robin97396's Avatar
I was changing about 27 tires per day by hand working in a rock pit, and they never had a cage. That was in Alaska.
Robin
Nobody's Business
Old 04-09-2017, 07:29 PM   #16
I used to live in a place with a bunch of asbestos in the ceilings.
But I wouldn't recommend it.
Roll Your Own Build Thread
Old 04-10-2017, 02:38 PM   #17
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Just in case you weren't sure about the "cage" this is one of a couple we still have kickin' around. Not in use anymore. We have just over 2000 power units and just under 20,000 trailers and just retired the last split rim trailer...a 1972 tanker.
Old 04-10-2017, 03:17 PM   #18
Being lucky 99 times out of a hundred is what these guys have a claim to...
Old 04-10-2017, 03:52 PM   #19
Originally Posted by REDD View Post
Attachment 13125
We where doing demounts and mounts for a military vehicle facility. They would break a vehicle down to components, inspect and either replace or repair including the frames. We got the stuff that the officials deemed off limits for the inmate labor. We did all of the tires and the removal of the brake shoes. For the brake shoes we got the entire axle. It was good work for two to three years until the military changed their minds and stopped the program.
Old 04-10-2017, 04:39 PM   #20
what size 19.5s did you get? the ReddByrd has good tires.. but Id love to get taller ones.. but seems 19.5's are a PITA to find in other than Light-truck style sizes...
