01-04-2023, 12:00 PM
Advice on how to move a non-running skoolie on my property
Hi everyone, first post here and looking to get into the skoolie life but in an unconventional way. I want to purchase a totaled bus (front end damage) and renovate it on my property (2.5 acres with a home) for myself to live in. It would be out of auction and not running, since I don’t plan on traveling in it (I know its a skoolie sin forgive me). I want advice on how to move it around once it gets towed here, it would be a rolling bus and I’m constantly changing stuff around on my property so would need to move it around every so often, short distances and not on the road at all, just dirt and gravel and flat. I have thought about some kind of winch on the rear end or something but want some advice from the skoolie people themselves. What would you do? Thanks!
01-04-2023, 12:23 PM
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
A decent sized farm tractor or a pickup truck with enough oomph to move it. If the tires are aired up and the driveshaft is disconnected, there's not much rolling resistance just sheer mass. Oh, and if it's air brakes you'll really regret this decision because without airing them up air brakes fail in the engaged state so every time you move it you'll have to build up it's air supply to release them OR cage the air brake chambers but then it'll roll freely all the time. So in the latter case treat it like a wagon and chock those tires!
01-04-2023, 12:39 PM
Thank you for the quick reply! That’s what I figured since its not proper towing on a flatbed or anything. Do you think a v8 1500 would get the job done like a chevy 5.3 vortec?
01-04-2023, 12:42 PM
01-04-2023, 03:36 PM
Chassis: 31 ft. HDX
Engine: CAT C7 250 hp
Rated Cap: 36,300 GVW
How big is the Bus ? A 40 footer or a small cutaway van? If it is a big one, you are talking about 10 tons of mass, so that 1500 will be along for the ride !
01-04-2023, 04:27 PM
Yup looking at a few full size school busses, but again its on my property, flat and pulling a rolling bus for short distances, we’re talking a couple hundred feet at any given time at most. You think the 1500 would be eaten up just grabbing the hooks and pulling?
01-04-2023, 05:40 PM
Engine: 345 international V-8
Does the 1500 have 4 wheel drive? That would help, also put weight in it. Traction will most likely be the bigger issue, not engine size. I do expect it would do ok on hard flat ground.
As already mentioned you will have to cage the brakes, or air them up.
01-04-2023, 06:27 PM
Chassis: Ford F53
Your best bet would be a 4x4 pickup truck with a 4-Low transfer case. That'll be slow but it'll move. Then as mentioned traction is the biggest factor so load up that pickup bed with weight to give it traction.
01-04-2023, 06:39 PM
Year: 2006
Chassis: IC CE300 (PB105)
We used to haul dead party buses to the scrap yard behind my mechanic's late-90s model Dodge 2500 in 4-Low via a good size length of chain
01-05-2023, 01:01 PM
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Trailer Conversion
If you are intending to remove the excess weight, enginge/trans, linkage & brakes...
It may not weight that much.
Two threads on the subject
(trailer & puller)
www.skoolie.net/5th-wheel-bus
www.skoolie.net/short-bus-shortening-for-towing-5th
01-06-2023, 01:41 PM
+1 on a decent 4x4 pickup in 4-low, but only if on flat, dry ground. If there's slope or the ground is soft I'd recommend some flavor of construction equipment. Something on tracks preferably. Size would increase with the slope you'd be moving it on.
Since you said it was flat ground, I'd think your z71 should work as long as it and the ground are both solid. Just remember that spinning your tires isn't the way to go unless you want to tear something up.
Oh, and most importantly, don't misuse chains, straps, or ropes. There are ropes and straps that are meant to be "jerked" (look up kinetic ropes), but even then it's easy to have something break and turn into a very-much deadly projectile if you yank on things like many instinctively want to. Especially if you're trying to move a bus like that...
01-11-2023, 03:20 PM
Chassis: Carpenter
Moving Skoolie that doesn’t run…
Assuming that it has air brakes you will need to run an air line from your bus air tank to a tank capable of filling it up so you can charge your air brakes.
After doing this, you should be able to drag it around with a half to three quarter ton pickup.
01-11-2023, 03:27 PM
or just cage the brakes.. much easier
01-11-2023, 03:28 PM
I do have to wonder WHY though? there are MUCH better things to live in stationary than a school bus..
01-11-2023, 04:24 PM
Chassis: Ford F53
*Shrugs* we're all a little crazy around here anyways.
01-11-2023, 04:29 PM
Rated Cap: 40 Prisoners
I would not limit yourself to a totaled bus. I would look for one that is drivable and drive it to your property and avoid the tow bill then sell the drive train out of it. Sometimes the motor and transmission are worth more than you paid for the bus.
01-11-2023, 05:03 PM
You have lose nothing trying it with the 1500. Chain around the hitch and move it a few hundred feet? Yup, I bet a pickup will do it just fine. Load all available kids and adults in the bed for weight if you need traction. Or if that's no fun, then a tarp in the bed and run the water hose until it squats on the springs (meaning it'll hook up enough to accomplish the mission). Slow and easy and remember the 2000lbs of water sloshing is going to make things tricky if you build up a head of steam. Low gear the whole way is my thought.
Also, unless it's on uneven land, it's not going to roll on its own so disabling the brakes is viable and of course, chock the wheels as someone else mentioned. If per chance there are functioning air brakes, then a small compressor powered by a 2000W Harbor Freight 12V-110AC converter should work well enough with a 20' extension cord to build enough pressure to release and function. you need a driver in the bus, too so it's not a one-man job.
Note; leave the truck running whilst the compressor is running to keep from running down the pickup truck's battery.
Anyway, assuming you're not doing this weekly, meaning just a few times before you figure where it's not going to be in your way too much, then your idea for using a pickup truck strikes me as sound. And if not, then maybe entice a neighbor to use his John Deere in exchange for a case of beer, or something, occasionally. Good luck!
Closing thoughts; once you're not moving it without an Act of Congress, score some 16x16 pavers and some 4x4 posts and block the corners. 1/2 x 6 Lag screws will let you bolt together three vertical pieces per corner so they won't tip or shift. They won't be perfect so shim the low corners until it approximates level to your satisfaction and call it done . . . new living space for cheap!
01-14-2023, 10:07 PM
Find someone close by that has a farm tractor. Either farmer or tractor restorer. Since you probably wont have brakes you may need to fabricate an A frame swing up tow bracket. Tractor restorers love to pull anything for fun. Farmer offer him some cash or beer.
01-15-2023, 10:31 AM
Coachwork: Bluebird 35 shuttle cng
Engine: John deere
Parking dead bus
Make sure that when it gets to it's parking spot you park it on some pavers or keep it off the dirt. Then make sure you keep the tires inflated. I have had trailers that I haven't used for several years and the tires that leaked down just fell apart in the mud and the ones that were full at least were able to roll even if they weren't road worthy.
Also like others I suggest not getting something that's wrecked for several reasons.first it's an extra hassle to fix it so it looks decent. Then if its wrecked it most likely was a running drivetrain before the accident so someone bidding on it might pay more for the drivetrain than you think. Then it might be cheaper to buy one that looks nice but has a blown engine because there would not be much competition for it
01-16-2023, 08:29 AM
Chassis: chevy
Engine: 3116 catapillar
loosen the slack adjusters or cage the spring if it air. do make sure you chock your wheels. no need for air
