RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-14-2020, 12:05 PM   #1
Year: 2009
Coachwork: Mid bus/collins
Chassis: Chevy express 3500
Engine: Chevy 6.6 duramax LMM
Rated Cap: 26
All terrain tires
So....I took the first step and bought a bus. Before I start the conversion, I want to make sure it is road worthy. Any thoughts on all terrain tires on the drive tires? They aren’t big tires by any means (225x75R16’s)
Wildland909 is offline   Reply With Quote
Old 02-14-2020, 01:02 PM   #2
Buses are loud enough by themselves. All terrain tires are going to be noisy.
Old 02-14-2020, 01:08 PM   #3
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Best thing I ever did was install light all terrains on my shuttle bus. I use to get stuck on wet grass but now make through fairly nasty mud. Of course my shuttle is a lot lighter than a skoolie.
Old 02-14-2020, 01:10 PM   #4
DawgBüs's Avatar
Year: 1982
Coachwork: Ford
Chassis: E-350; 4x4 Minibus
Engine: 351c.i.
Sounds like a cutaway bus? I had the same size tires as yours on my cutaway Ford and went up to 285/75R16. I have a minor lift though. Whatever you buy, make sure you can fit them under without hitting anything and especially while fully turned to either side
-Travis & the DawgBüs
<<1982 E-350 cutaway, Collins Bantam ext. body, Maximum 4x4 F-350 drivetrain conversion>>
DawgBüs is offline   Reply With Quote
Old 02-14-2020, 01:13 PM   #5
Year: 2009
Rated Cap: 26
Thanks
The noise isn’t a concern for me. I currently live in Maine where traction is a concern in the winter. As well as mud where I plan on relocating to.
Old 02-14-2020, 05:56 PM   #6
If traction is a concern get ya some M+S tires.
I'm running some meaty open shoulder tires on my shorty. They're great on the dirt but do make a good bit of noise on the pavement.
Wear A Mask- Stop the Spread!
Old 02-14-2020, 06:31 PM   #7
Year: 2009
Rated Cap: 26
I was thinking of 6 of these plus a spare
File Type: jpg EC3D0252-1573-4926-8F95-FAEA61304068.jpg (219.0 KB, 52 views)
Old 02-14-2020, 10:32 PM   #8
Chassis: IH
I wouldn't bother with aggressive tires on the steering axle, unless it's a 4x4.
Old 02-15-2020, 12:00 AM   #9
I sure wish my 11R22.5's were that cheap! They cost 5.5 times that!
Old 02-15-2020, 09:55 AM   #10
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
"Traction tires" are not normally bad for highway use. As noted, they are noisier, may not be as smooth of a ride (depends on tire), and probably won't get the same wear life (on asphalt).
The tires listed are retreads and I'm one of those that has had one come apart (here). I have no interest in ever repeating that so won't own another retread. Obviously, tires fail for various reasons and being a retread is not the ONLY reason.
JD - Full timer out west
My Adventures & Build
Old 02-19-2020, 11:54 PM   #11
What ever you choose- get the highest rated sidewall and ply rating. Nothing worse than making a hard turn and feeling the sidewalks lean. Heavier rated tires are great!
Dirtdoctor is offline   Reply With Quote
Old 02-20-2020, 10:51 AM   #12
WIbluebird's Avatar
Engine: 8.3 Cummins ISC
Rated Cap: 75
We run open shoulder all terrains on the work buses so that is what I will be doing on my skoolie. The extra traction is nice and the added noise doesn't bother me.
My company used to (and still do ocasionally) run steers on the rear. HORRIBLE traction like get stuck on dry grass bad. They are quiet though.
Old 02-21-2020, 11:39 PM   #13
I agree with Marc.
I switched from highway tread to A/T tir s on one of my trucks when I moved back to snow country. I hated them. I was shocked at just how loud they were and my fuel mileage dropped 2mpg.
If you insist on taking your bus where A/T tires are needed then you will have to live with it.
