It may be a 32', and the seller isn't completely aware of it.
Regardless, I would avoid anything from California, as they're such nazis with the emissions equipment--which is tied to the VIN, so you'd either have to break the statutes, or deal with that mess all the time. Most of the emissions equipment are patches to correct a problem that is more easily solved by changing something else earlier in the engineering, and often usually is. Catalytic converters, for example, are one such thing, that is hardly needed considering the average emissions of the modern Otto-cycle engines, and in order to function properly, the engine has to be designed to be more wasteful than is necessary. It is entirely possible to run a clean engine without all of that mess, especially with modern ignition-control and fuel systems.
