Split lock washers really don't make any sense. Their rationale is that they're springs and the upward force on the bolt they provide produces friction that prevents the bolt from turning. But: that is exactly how bolts work on their own, with the torque producing a far larger upward force on the bolt (and correspondingly far larger frictional force) than anything you get from that weak little spring slightly compressed.
I am not sure that I agree with the above statement.
A split lock washer is made of spring steel and should be slightly harder then the other two materials. A split lock washer is made in such a way that the edges are sharp and they dig into the bolt and base material. For that reason a lock washer should not be overtightened because that would flatten the sharp edge. For higher torque there is the high collar split lock washer.
You will feel its effect if you untighten the nut. There is a small hesitation in the beginning because of the shearing of the sharp edge.
So in theory you should use a lock washer only once.
A lot depends on the application and then of course knowledge and experience of the person who uses them.
In Ross's wind turbine generator example more issues are important.
This is a high dollar equipment in a very complicated environment and it would be simply not worth the risk to use a lock washer if a better, albeit more expensive solution is available.
Johan
