Old 11-20-2023, 06:46 PM   #1
IDoMy0wnRacing's Avatar
Year: 1977
Coachwork: 1977 & 1980 Gillig's
Chassis: Transit Coach
Engine: Cummins NHHTC-290, Big Cam 855 w/RT-910
Rated Cap: 97 & 78-Passenger
ASC Button
Good day ALL,
I just picked up another bus.
This one is a 36 foot, 1990 Thomas Saf-T-Liner, WestcoastER.
3208T, Allison MT643.
There is a button on the back wall that reads ASC (pictured). I do not know what it is for?
Any ideas?
Thanks all.
Ed
Cruising in your Skoolie is only half the fun...
You get to build it first.
IDoMy0wnRacing is offline   Reply With Quote
Old 11-20-2023, 07:56 PM   #2
Year: 2010
Chassis: Blue Bird (6-window Handy Bus)
Engine: Cummins 6.7l ISB
Rated Cap: 15 + 3WC
I had a button in the back of my bus that was essentially a check button to make sure no students were still on the bus at the end of the day...cant remember what exactly it did (never checked)...
desrtdog is offline   Reply With Quote
Old 11-21-2023, 11:01 AM   #3
Year: 2010
Rated Cap: 15 + 3WC
...not sure if that what your button is, but here's another thread on the subject...
https://www.skoolie.net/forums/f9/th...elp-39381.html
Old 11-21-2023, 02:17 PM   #4
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
I believe the ASC is unrelated to the button, which is most likely a child check button. That looks like an enterprising mechanic mounted that button with a large fender washer they drilled...and the ASC is, I am pretty sure, the Home Depot item code for pulling it up when you check out at the register.
Old 11-21-2023, 05:49 PM   #5
In the school bus trade we call that the "no child left behind" button although that's not its real name. After shutting the bus off - if you've activated the red flashers and stop sign at any point in your trip - you need to go to the back and press this button or else the bus will start honking and flashing its lights in a few minutes, alerting everyone in the bus depot to what a moron you are. The theory is that this will force you to notice any kids still on the bus, although in our depot there have been a few occasions of drivers going back and pressing the button without seeing a sleeping kid.
On some buses there is only a light on the left-hand switchboard to remind you that you need to hit this button; on Internationals they usually have a steady beeping sound to remind you.
I had thought this was sort of a modern thing since my 2003 didn't have one, but yours is a lot older than that so maybe it's a state-by-state thing.
Old 11-21-2023, 11:15 PM   #6
Year: 1977
I am not sure if it is a state thing either.
Thank you very much for the detailed explanation.
Ed
