Old 10-21-2021, 02:38 PM   #1
Awning Location
So I got an 18' awning to mount to the passenger side, Question is should I mount it forward to cover the entrance door, or midway on the side? Going on an FE.
Old 10-21-2021, 03:05 PM   #2
dzl_'s Avatar
I see value in option #1 -- cover the entrance door, if you encounter rain/snow often.
dzl_ is offline   Reply With Quote
Old 10-21-2021, 03:09 PM   #3
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
I'm with dzl...if your door won't hit the awning when it opens. Do you still have bifold or split doors, or did you change to a single which swings out?
Old 10-21-2021, 03:09 PM   #4
Is it going to be in the way of the door operation?
Old 10-21-2021, 03:10 PM   #5
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
I have one I've never opened (I don't know how) . It's mounted a few feet back from the entrance. It seems like that would give you a larger "patio" area although a little shade over the entrance might be nice. Be careful your door doesn't snag it
Rwnielsen is offline   Reply With Quote
Old 10-21-2021, 03:26 PM   #6
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Funny...3 of us all cautioned about the door at the same time. We're aligned!
Old 10-21-2021, 03:31 PM   #7
Rwnielsen's Avatar
Rated Cap: U/K
That is pretty funny, I thought I was the first response...we must have been typing at the same time
Old 10-21-2021, 03:32 PM   #8
There would be no interferance with the operation of the door. I can mount the front stay just in front of the long skinny window.
Old 10-21-2021, 04:21 PM   #9
Rwnielsen's Avatar
Rated Cap: U/K
There are rollers available if it does get to close, I've seen them on RV's
Old 10-21-2021, 05:00 PM   #10
Ya, this will work. it will end just in front of the center clearance light, covering the door and 2 windows.
Old 10-21-2021, 06:24 PM   #11
Looks about perfect.
Old 10-23-2021, 05:19 PM   #12
Looks can be deceiving. Remember when I said it would end right near the clearance light? Remember boys and girls, always measure TWICE, cut ONCE. While those upper measurements worked great, it would have put the lower left attachment right in the middle of the storage door. So I moved it back to the only workable location, between the wheels.
The awning material is 17', plenty of coverage. Just waiting on some rail to attach the fabric to the roof.
Old 10-27-2021, 03:44 PM   #13
You could always make a separate awning just for the door. Wouldn't need alot of support. Overlap the main awning.
rebapuck is offline   Reply With Quote
