Originally Posted by thewanderbusco
Hey all! We just started demo and I’ve been hesitant to pull the trigger on a specific camera purchase. I want something fairly easy to use that I can mount, but also take down easily when I want to show real time with audio. Hoping to go with refurbished under $300, but have some wiggle room there. I’ve looked at GoPro, Brinno, and DJI. Any recommendations appreciated!
We have a YouTube channel for the bus and I have two other channels. For time lapse nothing beats my GoPro. I set it on 5 second interval and every 5 seconds it takes a pic. For mounting it there are all kinds of options.
On a ball cap on your head
On a standard tripod on the floor or ground
On a flexible leg tripod that can be hung off a ledge, put on the floor, or anywhere else your imagination leads you.
I've even mounted mine on a cardboard box that was fixed into the overhead front of my bus with a three sided "bay" to slide the camera into and ensure that I have the exact same placement every time.
You can see an example of what the GoPro time lapse looks like on our YouTube channel "HamSkoolie" We're just starting to transition from demo to build so all that's in there are demo time lapse and two videos on the Vermont title thing.
One thing about the GoPro and it's no biggie once you're used to it is that it doesn't shoot (at least mine doesn't) in the proper aspect ratio of 16:9 which means that in editing you'll have to crop things but no biggie and yo don't have to crop every time lapse image.
For video, I DO NOT use the Go Pro. I use a Sony handi cam with the flip out from the side view screen that I can flip 180 degrees and see whats in frame as I'm shooting myself.
I also run a Sony digital recorder the entire time which allows me to more easily align shots from different sources (by aligning the voice patterns) and to keep the audio level consistent across video sources.
