Old 09-27-2019, 09:27 AM   #1
Chassis: 2000 Int Amtran
Engine: DT466HT
Best RE body for raising roof
Anyone want to chime in what bus body is the least hassle free with interior gutting and raising roof?
MacC is offline   Reply With Quote
Old 09-27-2019, 10:16 AM   #2
Engine: DT466E-Md3060
They are all hassle free...yeah right...just a lot of work!!!
I'm doing an Amtran RE right now, the back of the bus, the back wall panel and side air ducts were quite a task.!
All that has to be removed in order to have access to the hat channels.
Ceiling panels with screws were easy just use an S2 "Square " bit, from harbor freight, instead of a standard phiilps head bit.
If the screws don't budge just give them a qhad whack with a hammer and toggle the drill forward and backward, they will come loose!
ewo1 is online now   Reply With Quote
Old 09-27-2019, 11:31 AM   #3
Thomas built buses taper at the base of the windows, making roof raise interesting. Internationals are easy to disconnect the roof.
Old 09-27-2019, 11:36 AM   #4
IC/AmTrans.
Roll Your Own Build Thread
Old 09-27-2019, 12:43 PM   #5
Coachwork: In the market
Seconded regarding Thomases but if you're good with angles it could prove a benefit. Admittedly I haven't tried this yet but my thinking is if you could extend that slight window pitch as you extend downwards you could essentially reclaim 6 inches of body width! In other words, school buses being 96 inches wide but standards allow 102 inches. How you utilize the space seems like it could be problematic but it's an idea.
Sehnsucht is offline   Reply With Quote
Old 09-27-2019, 12:48 PM   #6
The Thomas angle starts at the windows. No space to be gained.
Old 09-27-2019, 01:54 PM   #7
Engine: DT466HT
Checking out your roof raising as I type.
Old 02-15-2020, 07:39 AM   #8
Engine: DT466HT
Well I bought an Int AmTran\. ewo1 I will be asking questions, let me know if that is a problem.
Old 02-15-2020, 08:36 AM   #9
I was stopped behind a C2 yesterday, and I noticed that the angle is non-90-degrees all the way to the floor. It's a very slight curve, steeper at the top than the bottom, but it appears that no part of it is a 90 angle.
musigenesis is online now   Reply With Quote
Old 02-15-2020, 08:39 AM   #10
Yeah they're a much more complex shape.
Old 02-15-2020, 09:05 AM   #11
Ask away, besides me, there are alot of good people here than can help!
Old 02-15-2020, 09:19 AM   #12
And even the bad people here can help!
Old 02-15-2020, 09:53 AM   #13
I've always thought if I was going to attempt a roof raise I don't want to start at the front header but rather to begin about at or just aft of the front axle on an RE... kind of reminiscent of a SceniCruiser. Also perhaps some amount of slope in the back window or a rounded end cap for the tail. My imagination however exceeds my skillset!
Old 02-15-2020, 10:49 AM   #14
Roof raising isn't too bad. To make it look GOOD you just have to take your time.
