Old 04-04-2024, 12:00 AM   #1
Broken door window
One of the windows of the passenger door shattered completely and I need a replacement. What kind of place would be best to get one/have it replaced? And is there any way to do replace it myself?
The door/windows style is very similar to this picture.
Hakunamatata is offline   Reply With Quote
Old 04-04-2024, 09:09 AM   #2
Chassis: Ford E450
Engine: V10 Gas
Take some pictures of your door and bring them to a glass dealer. They will quote you a replacement pane.
Usually there's just a gasket you gently remove from one side or the other, clean out any broken glass, lay in the new glass and replace the gasket.
Share detail pics here.
Also, put your rig information in your profile so we can see what vehicle you have.
Old 04-04-2024, 12:35 PM   #3
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
There are mobile glass repair guys that can do this kind of thing.
Take a picture, and some good measurements of the glass, and start calling glass shops. Cutting custom glass is easy enough, especially if it's some kind of square or other polygon with straight edges. I promise that someone in your area can handle it very affordably.
And it's even more affordable if you do the installation yourself, which isn't too complicated; just make sure that everything is clean, clean, clean.
Albatross is offline   Reply With Quote
