Get under the bus and grind off the bolt sticking down through the plywood, then they come out. The problem are the ones above the fuel tank you can't get to them to grind or put wrench on the bolt. Frankly I'd just leave them there, they are mostly countersunk so not a big issue, at least mine were. I removed my fuel tank, so I can get the problem ones out.
