Old 04-04-2020, 06:16 PM   #261
Originally Posted by banman View Post
Mine are a pair of group 31 batteries. Standard truck batteries...
"Physical dimensions of BCI Group 31 batteries are approximately 13 x 6 13/16 x 9 7/16 inches (~13 x 6.8 x 9.44 inches, 330 x 173 x 240 mm), and they weigh anywhere from just under 30 pounds (lithium batteries) to almost 80 pounds (lead-acid batteries)."
There's easily room for 3 of these batteries. I think 2 was the usual configuration.
Attachment 42824
dang banman... you better get to work cleanin up that tray.
IDK why but battery compartment cleanliness is important to me! Its sorta my pet peeve.
Old 04-04-2020, 08:32 PM   #262
Dummiesman's Avatar
Do any of you have the pull handle parking brake?
If so, where is it positioned when it's active, and where is it positioned when it's off?
Also, batteries! My battery compartment is weirdly large looking. Probably because it's missing the sides where the door rests. One more thing for the todo list I guess
Dummiesman is offline   Reply With Quote
Old 04-04-2020, 08:44 PM   #263
I've conveniently got the WHOLE battery compartment of my fs-65 taken all apart. YOu want me to measure the tray they sit on and take pics for ya?
Old 04-04-2020, 08:51 PM   #264
Dummiesman's Avatar
That could be helpful, yeah. Hmm, is it taken apart for cleaning purposes?
Old 04-04-2020, 09:42 PM   #265
Yeah Its something I do on every bus. Pull the batteries, scrub it all down. Treat any rust, sand it a bit and repaint it. Good for another 20 years.
I had some brand new batteries even though these aren't dead.
I'm in the middle of the project should be done in a day or so.
Old 04-04-2020, 10:40 PM   #266
Dummiesman's Avatar
I've been having some fun with this recently.
Gave it some flames
A grille guard
A wire crossing guard
and an admittedly too high tow hitch
Old 04-04-2020, 10:45 PM   #267
A 4" or 6" drop hitch should straighten that trailer out!
Old 04-04-2020, 11:41 PM   #268
The tray's fine -- it's the rust holding the box to the body that concerns me...
Seriously -- I don't need to clean it till I'm ready to weld it -- which is a priority...
David
The Murder Bus
Old 04-05-2020, 12:12 AM   #269
Dummiesman's Avatar
Took a whole 9 inches to get it to an acceptable level
I improvised some structural support to handle that drop
Old 04-05-2020, 02:08 AM   #270
Very good! Looks like that toad rides well.
Now, drive it all off a cliff and see where the pieces lie.
Old 04-05-2020, 02:51 AM   #271
Dummiesman's Avatar
Just want to double check. Is this the proper light configuration?
A loading screen tip in the game just reminded me that fog lights are actually implemented in the game, and if those are actually foglights, I should add them.
Old 04-05-2020, 03:58 AM   #272
You got the brake, signal, and backup lights right. There is no "fog" switch on the dashboard so no fog lights. I have rewired our back-end so I can not confirm the function of those little red lights. My "guess" is that they are running lights or secondary brake lights.
Old 04-05-2020, 11:20 AM   #273
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
On my bluebird those "fog" lights were listed as license plate lights. Reverse lights are definitely clear, no matter the manufacturer. Mine are up next to the other two lights. (but like I said its a bluebird)
The license plate lights stick out more, the plastic is red, but there is a clear window on the bottom, so it's not a red light shining on the plate.
JDSquared is offline   Reply With Quote
Old 04-05-2020, 11:39 AM   #274
plfking's Avatar
Rated Cap: 34
Those are the cleanest virtual welds I have ever seen.
Don
The Busted Flush
Old 04-05-2020, 12:09 PM   #275
Dummiesman's Avatar
I've found this hill is more fun. More gradual destruction and you get to hear all the glass break
Old 04-05-2020, 12:42 PM   #276
You removed the upper warning lights and eyebrows for the "skoolie" model?
The lower red lenses have clear openings on the bottom to illuminate the tags and serve as additional running lights.
Name:	Tail lights.jpg
David
The Murder Bus
Old 04-05-2020, 01:05 PM   #277
Dummiesman's Avatar
Attachment 42846
Oh, that makes some sense!
Yeah I removed them on the Activity, Shuttle, and "Privately Owned" presets. Though they're just presets and always can be customized
Old 04-05-2020, 02:39 PM   #278
Phantom5824's Avatar
Coachwork: Gillig
Chassis: Phantom 40'
Engine: DDECII 6V92T Allison MT647
Rated Cap: 37,400 lbs of potential
OK! Now, THAT was fun to watch.
Who said that this isolation would be unproductive?
Very good, Dummiesman, thanks for the laughs
Rich
Phantom5824 is offline   Reply With Quote
Old 04-05-2020, 04:04 PM   #279
I think that was the quickest demo work I have seen on this site yet! Bravo!
Old 04-05-2020, 04:23 PM   #280
Attachment 42846
I found an old picture of our back-end.
Well now, there is another little difference between our twin buses. Ours has a separate license light.
Name:	20170102_150622 Original Back View.jpg
Apparently, it had a bit too much to drink the night before.
