Old 04-27-2020, 04:51 PM   #361
I'll locate the owner manual ... it describes them all.
Old 04-27-2020, 05:05 PM   #362
This is a manual from an older model, but it does explain most of the indicators.
school bus chassis operator's manual.pdf
Old 04-27-2020, 07:10 PM   #363
Dummiesman's Avatar
Ty! That's a great help.
Now all I need to do is put the lights in
EDIT: there we go
Dummiesman is offline   Reply With Quote
Old 04-28-2020, 12:12 AM   #364
Aw man ... a brand new machine and you already have an air leak!
Say why are both of your turn indicators on?
Old 04-28-2020, 12:27 AM   #365
Dummiesman's Avatar
Wait what? Air leak?
Hazards were on. I was just testing if they worked on the dash too
Old 04-28-2020, 12:59 AM   #366
Yeah man, your air pressure was near zero. Does the simulation "remember" the settings from the last use?
Old 04-28-2020, 01:01 AM   #367
Dummiesman's Avatar
Oh, that was only a couple seconds after startup. Didn't have the pressure light ready yet.
Every time you load up the vehicle the oil pressure, and air pressure have to come back up.
Old 04-28-2020, 01:39 AM   #368
In the real world, the air pressure is held in the tanks after the engine is turned off. If you have a leak, it slowly drops. In my bus, it drops to below 60 PSI over night most of the time. Inn others, it stays filled up for weeks on end.
Old 04-28-2020, 07:01 AM   #369
Dummiesman's Avatar
It resets each time you load it up just so you can hear the buzz/alarm upon starting. I know it's really short, but otherwise I'd get "Why is this thing constantly beeping it's so annoying!!"
The air pressure gauge in-game doesn't reflect anything anyways, it's just for show.
Oh, btw, how does the cluster look at night with the lights on? Having trouble finding a good reference for that.
Also, not related to the simulation, but, why do these older buses have 'jumpy'/'jittery' gauges sometimes?
Old 04-28-2020, 02:19 PM   #370
Dummiesman's Avatar
(I wish that 'edit' button showed up a little longer)
Oh, by the way, simulating driving buses is a relative niche in the gaming world. While people may look at what I've done here and think of how it could be used for bad, there's also some people who just want to drive a bus, whether as something to pass the time, or as something as an in between to actually driving one IRL.
I'm glad that it's reached those audiences as well. Watching these kinds of videos puts a smile on my face, knowing that people are genuinely enjoying using it and are noticing all the little things
Old 04-28-2020, 10:31 PM   #371
My wife says the same thing every time I start the engine. At least yours is a second, not a minute or two. I would love it if my pressure built up that quickly!
I do like the way your bus sounds.
Here is a shot of our cluster at night:
Name:	20200428_211225 Instruments at Night.jpg
Bear in mind that I have replaced my instrument lights with LED lights and I keep the dimmer switch turned down to just enough to see while driving at night.
The instruments get jittery because they are old. The connections get corroded and the constant shaking that the buses endure make the connections get loose from time to time. I am glad ours is not one that does this.
Old 04-28-2020, 11:30 PM   #372
Dummiesman's Avatar
So the entire gauge cluster, with the exception of the odometer, is greenish backlit?
edit: how's this?
Do I need to give the gauges a slightly more turquoise tint?
Old 04-29-2020, 01:29 AM   #373
Not green, white. The green does look good though.
Old 04-29-2020, 01:40 AM   #374
Dummiesman's Avatar
Does the text itself glow green though? It looks like the text is green, and the 'notches' are white in your picture.
Old 04-29-2020, 02:26 AM   #375
I had not noticed that before. I suppose it is phosphorescence. When driving it looks yellow if anything. The picture does look to have a slight green tinge to it. You have a good eye.
Old 04-29-2020, 04:12 AM   #376
I just finished watching the whole show ... it was a riot! The guy was flabbergasted when the AI cars stopped for the school bus when the door was opened. The AI school bus was another story!
Old 04-29-2020, 08:30 AM   #377
Dummiesman's Avatar
Cars think the bus is larger than it is, so technically they stop because they think there's an obstacle in the road. Though I don't know why the other bus stopped steering and instead accelerated straight at him
Hopefully this is correct now
Old 04-29-2020, 11:30 AM   #378
Dummiesman's Avatar
Oh yeah, is there really no "low fuel" light? I was looking at that manual and the fuel one is actually just water in fuel separator
Also, with the air gauges, are they just stacked like this, or is the orange one flatter?
Old 04-29-2020, 04:41 PM   #379
The car were pulling in front of the 'big bus" when it was not displaying the stop sign/flashers. As soon as he turned them on they stopped. A couple tried to turn around.
The gauges in white are perfect!
There really is no low fuel light. I've been down to 5 gallons once, no light. When I turn on the key before starting the engine, all of the lights come on for a bit. There is no low fuel indicator then either.
The primary (white) and secondary (orange-red) indicator needles are the EXACT same size and shape.
Old 04-30-2020, 11:18 AM   #380
Dummiesman's Avatar
Does someone know what these side mirrors are called?
I've been trying to find references for them to add them as an option to my model but I've only found front facing pictures like this.
